G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: tack1000 on June 04, 2012, 01:24:08 AM
Title: OneCNC to G-Code has an issue with arcs
Post by: tack1000 on June 04, 2012, 01:24:08 AM
Hello
I have been working with Onecnc for a while now for a local machine shop. The machines they have are Haas's of different types.
I made a small DIY mill some time ago and have been using Mach3 to run some programs I have written and the wizards have generated.
I'm in the process of making a bigger DIY mill so I can machine slightly bigger parts but with better finish and accuracy as the stepper motors are direct drive now not belt drive as before.
So to my problem.
When I use Onecnc to generate the G-Code Mach3 shows a line error as the pic shows.
(http://i1102.photobucket.com/albums/g456/tack1000/Capture7.png)
I have used the Mach3 code generator within Onecnc but no go can anyone help with this issue.
Thanks in advance.
Tack1000
Title: Re: OneCNC to G-Code has an issue with arcs
Post by: BR549 on June 04, 2012, 11:29:15 AM
Either your program MISSED when it wrote the G code OR your IJ setting (inc,abs ) is incorrect.
Just a thought, (;-) TP
Post by: aldepoalo on August 30, 2012, 01:55:43 PM
Switch your post setting to XYR   for your arc settings.
