Third party software and hardware support forums. => Mach3 and G-Rex => Topic started by: Trin33 on June 03, 2012, 03:42:01 PM
Title: Mach3 Joggin Y & Z normally, X is slow like molasses
Post by: Trin33 on June 03, 2012, 03:42:01 PM
I learned earlier how to jog using CTRL + J and have been alternating between functions today. The only problem is that my X axis now seems to be stuck on the slower jog rate. All my Motor Tuning is the same for the axises, and everything has worked well. Z & Y alternate fine between the speed rates.
Restarted Mach3, Rebooted computer, and checked all the jogging settings. My diagnostic screen is not showing any limits setup.
I can still set to the lower jog rate (and then everything moves the same speed). Why is just my X axis stuck on tortoise? Please help!
Appreciation in Advance...
Title: Re: Mach3 Joggin Y & Z normally, X is slow like molasses
Post by: Trin33 on June 03, 2012, 03:55:26 PM
Okay, got this sorted (Duh!)
After putting my hand on the router and trying to feel the "pulse" of the reduced feed rate, I didn't feel it. I thought it had been moving, because Mach3 was showing the numbers change, and the increments had been so small I didn't notice before.
My cord was too tight and disconnected when I moved the access across my table. Duh!
-Newb on a Mission
