Mach Discussion => General Mach Discussion => Topic started by: bshaker1 on January 11, 2007, 05:41:50 PM
All the part programs that I load into Mach 3 always come out to where the part is to small to see in the view window. The part is in a Shaded box with a yellow dashed border around it, the part is in the bottom left corner and I guess it's the machine cordinates in the upper right corner. If I were to run this on my machine the part would be way off the table(machines limits). What am I doing wrong.
can you post the part file your having trouble with?
Yes I can It was a generic fanuc post from mastercam x
I have a Mastercam X post that works great. I would like to see the MCX file your using.
bshaker1,
I sent you a PM
