G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: ilkleyal on May 15, 2012, 02:54:02 AM
Hi
Question, when I draw a shape in Cambam using polyline, How do I determine its size? The tutorial video covers everything to do with creating and machining it but not how big it is.
Are the grid lines 1mm? if so, what if I wanted to draw something that was 50.5 between 2 points for example?
Hope you can assist
Al
Hi, patly answered my own question, yes, its 1mm grid lines. Can I change the resolution or is there another method to set a dimension between squares?
Cheers Y'all
Al
Don't use CamBam's CAD so can't be of much help other than to say if you don't get a response here that you go to the CamBam site
have a look at the videos, manuals, etc and maybe register for the forum and ask there.
Select the item in the menu tree and click on its properties, there will be a list with height, width etc, just enter new values and press enter.
Hi you can also use points > collection .... click on .... brings up the table which can be edited
