Mach Discussion => General Mach Discussion => Topic started by: daddog on May 13, 2012, 07:11:16 PM
Title: feed rate button on program run screen
Post by: daddog on May 13, 2012, 07:11:16 PM
Sometimes I would like to be able to speed up or slow down my feed speed when using my router.  I assume that the Feed Rate button should allow me to do that, but it doesnt.  What do I need to do to activate this feature?  Thanks
Title: Re: feed rate button on program run screen
Post by: BR549 on May 13, 2012, 07:42:00 PM
IF you have the standard screenset then in the Feedrate control block there are 2 arrows one pointed down with a - in it and the other is pointed up and has a + in it.
Click on either and the FRO will increase/decrease  by 10%   for each press of the arrow.
Post by: Hood on May 14, 2012, 05:45:24 AM
Think the standard screens now use a slider for FRO, you would just click and hold the left mouse on the green part of the slider and move the mouse up or down.
Post by: daddog on May 14, 2012, 12:43:51 PM
when I click on the arrows, the screen indicates that the speed is changing but in reality it does not change.
Post by: Hood on May 14, 2012, 12:49:08 PM
On general config page do you have No FRO on Queue ticked, if so untick. Other thing is you may be calling out a M49 in your code and that will disable FRO.
Post by: daddog on May 15, 2012, 07:36:04 PM
Thanks Hood.  The No FRO was ticked.
