Mach Discussion => VB and the development of wizards => Topic started by: HillBilly on January 08, 2007, 12:06:42 PM
What is the call for OEM Triggers?
I tried Get OEMTrigger (4) with no luck.
Darek
This is what I am trying to do,
Darek
If GetOEMTrigger (6) = 0 Then
If GetOEMTrigger (7) = 0 Then
DoOEMButton (191) 'Select Jog Incr 1
EndIf
If GetOEMTrigger (6) Then
DoOEMButton (192) 'Select Jog Incr 2
EndIf
If GetOEMTrigger (7) Then
DoOEMButton (193) 'Select Jog Incr 3
EndIf
DoOEMButton (194) 'Select Jog Incr 4
EndIf
I think the triggers start at number 29
So you maybe have to look at 35 and 36 to get the ones you want.
Graham.
Your right! This is what I ended up with.
Darek
If Not IsActive (34) Then If Not IsActive (35) Then 'Check OEM Triggers 6 & 7
End If
If IsActive (34) Then If Not IsActive (35) Then 'Check OEM Triggers 6 & 7
End If
If Not IsActive (34) Then If IsActive (35) Then 'Check OEM Triggers 6 & 7
End If
If IsActive (34) Then If IsActive (35) Then 'Check OEM Triggers 6 & 7
End If
