General CNC Chat => Share Your GCode => Topic started by: macatoms on May 08, 2012, 07:15:38 PM
IF ANYONE HAS THE KISS LOGO IN G CODE THAT WOULD BE GREAT.THANKS
Here is an outline engraving toolpath which could also be used with a vinyl cutter.
You didn't specify dimension so this is small but you can use the Mach Scale DRO's to increase the size.
Thanks man.I see you used v carve to make this file.Do you like it?Do you know if someone sells some older versions of v carve.The moneys the issue.Iam a vet on disability and cant spring for the good software.Thanks again Dave Mcadams.
Hi Dave,
I know the feeling, it took me 12 months of savings to purchase the VCarve license. :D
Just a note for others that follow - Logo's such as this are often registered or copyrighted and whilst there is no problem relating to personal use they cannot be used for commercial purposes or public display etc. without first obtaining the necessary permissions from the owner of the design.
I was wondering if you could make 2 more logos for me?I need the Megadeth logo and Iron maiden logo.If its to much trouble I understand!I thank you for your help and response.Also do you know much about lazy cam?Iam trying to use it but it seems to be kind of less than equal to the Mach3 standards.Thanks Dave
Hi Dave,
You are right about lazyCam - but it is extremely good at what it does despite not having all the features of other software's.
Logo's attached.
Thanks for making that code for me.Dave
