Mach Discussion => VB and the development of wizards => Topic started by: jewe on May 06, 2012, 01:22:08 PM
I've written a macro for an ATC carousel type using an Ac motor. Each motor rotation indexes the carousel by one position.
I can drive it CW or CCW. There's two inductive sensors, one fro the Ac motor rotation ( i++ or i--) and one for the carousel Home Position.
The carousel is sent in tool change position by an air cylinder, the only driven axis is Z.
I tried to use it and have a scripter compile error.
If someone would tell me what's wrong?
Thanks for your attention,
J.
Here's the code:
Sub Main()
'Global variables declaration
NewTool = GetSelectedTool()
OldTool = GetCurrentTool()
'Flow sequence
'Compare between actual tool and requested tool
call Compare
'Carrousel air cylinder position check : Home, in Mvt and ToolChange
call AirCyHome
call ToolChangerPos
'Move to Z tool position and wait until position reached
call Z_TcPosition
'Spindle Home Sequence
call SpindleHome
'Activate air cylinder valve to put old tool back to carrousel
call OldToolBack2TC
'Spindle: Tool Unclamp
call Unclamp
'Go to safe tool change Z coordinates
call Z_TcPosition
'Spindle: Tool Clamp
call Clamp
'Sequence to determine the least travel to move for TC, CW or CCW
call LeastTravel
'Turn CW or turn CCW integrated in above Sub
call OldToolBack2TC
call Unclamp
call Z_TcPosition
call Clamp
'Air Cylinder Homing
call AirCyHome
'Store new tool as actual tool value
Call SetUserDRO (1200,NewTool)
SetCurrentTool( NewTool )
' Compare between actual tool and requested tool
Function Compare() As Integer
Dim Compare As Integer
If NewTool = OldTool Then
Compare = 1
Else
Compare = 0
End If
End Function
Function ToolChangerPos() As Boolean
If IsActive(INPUT1)>IsActive(INPUT2)Then 'We are at Home Position
ToolChangerPos = 0
TCMove = False 'We are stopped
ElseIf IsActive(INPUT1)<IsActive(INPUT2) Then
ToolChangerPos = 1
TCMove = False
Else
ToolChangerPos = -1
TCMove = True
End If
End Function
sub AirCyHome()
DeactivateSignal(OUTPUT8)
AirCyHome=IsActive(INPUT1)
end sub
Sub Z_TcPosition() As Integer
code("G53")'Move in Absolute Machine coordinates
while(IsMoving())
Sleep(100)'temporisation entre while++
Wend
code("G00 Z-116") 'Z value as to be checked for exact match with carrousel height
while(IsMoving())
Wend
Z_TcPosition=1 '1 quand en position pour Tool Change
end Sub
Sub SpindleHome()
ActivateSignal(OUTPUT1)'activate spindle indexing for ToolChange
while(IsMoving())'Do nothing while spindle is rotating
sleep(100)
wend
'Maybe necessary to invoke a case select for tooling choice if more than 10 tools
end sub
'Spindle Release
Sub SpindleRelease()
DeactivateSignal(OUTPUT1)
end sub
'Put old tool back to carrousel
sub OldToolBack2TC ()
If Z_TcPosition=1 then
Activate Signal(OUTPUT8)'Move carrousel via the air cylinder to reach the tool change position
else
call Z_TcPosition
End if
end Sub
Sub Unclamp()
If IsActive(INPUT2)'Sensor indicates that carrousel is at tool change position then
ActivateSignal(OUTPUT9)'Release the tool, unclamp
End If
end Sub
Sub Clamp()
DeactivateSignal(OUTPUT9)'Grip the tool, Clamp
end Sub
Sub ZUp_TcPosition() as Integer
ZUp_TcPosition=0 'var init
code("G53") 'Move in absolute machine coordinates
while(IsMoving())
Sleep(100)
code("G00 Z-35")'Move to the safe Z position for tool change
while (IsMoving())
sleep(100) '0.1sec delay between loops
wend
ZUp_TcPosition=1
end Sub
'atp = Actual tool position, rtp = Requested tool positon
Sub LeastTravel()
NTool = 10 ' Number of tools changer holds
CWPos = GetSelectedTool() - GetCurrentTool() ' Assume a CW move
If CWPos < 0 Then ' CWPos < 0 ==> rtp < atp
CWPos = CWPos + NTools
End If
CCWPos = NTools - CWPos
If CWPos < CCWPos Then
call CW()
Else
call CCW()
End If
End Sub
'Rotation CW
Sub CW()
dim x as Integer
dim CTPos as Integer 'Carrousel Tool Position Relative to OldTool Position
CTPos=0
ActivateSignal(OUTPUT10)'Turns the AC Motor On
Do until IsActive(OEMTrig1)
Sleep(50)
loop
for x=0 to CWPos
If IsActive(OEMTrig1) then
x=x+1
While IsActive(OEMTrig1)
'Wait for OEMTrig to de-assert
End While
End If
next x
CTPos=x
DeactivateSignal(OUTPUT10)
End Sub
'Rotation CCW
Sub CCW()
dim y as Integer
CTPos=0
ActivateSignal(OUTPUT11)
Do until IsActive(OEMTrig1) 'Turns the AC Motor On
Sleep(50)
loop
for y=0 to CCWPos
y=y+1
End While
End If
next y
CTPos=y
DeactivateSignal(OUTPUT11)
End Sub
Main
Try;
While IsMoving()
Wend
Instead of
While (IsMoving())
Wend
I removed all occurrences and it doesn't give better results.
I also tried a very simple test by making calls to the clamp and unclamp subs only, without any change in the error message.
I'm a newbie in macro programming so I probably missed something but what...
J.
I didn't read the whole thing, and I'm no expert, but here's another issue. This:
while(IsMoving())
Sleep(100)
while (IsMoving())
Should be this:
Code "G00 Z-35"
While IsMoving()
Wend
You don't need the Sleep() in the While IsMoving().
Hi Gerry,
I tried that and other changes like a mix with(out) parenthesis :
IsMoving()<>(IsMoving())
code("G00 Z-35")<>Code "G00 Z-35"
This doesn't gave me any results.
I will try without using calls, maybe I'm not using them well:
Call Statement
Call funcname [(parameter(s)]
or
[parameter(s)]
Activates an Enable Subroutine called name or a DLL function with the
name name. The first parameter is the name of the function or
subroutine to call, and the second is the list of arguments to pass to the
called function or subroutine.
You are never required to use the Call statement when calling an
Enable subroutine or a DLL function. Parentheses must be used in the
argument list if the Call statement is being used.
Example:
Sub Main ()
Call Beep MsgBox "Returns a Beep"
End Sub
Source: Language Reference page 45 Cypress Enable for Mach
So if someone has a good idea, he's welcome.
Thanks for help,
J.
Everything I told you is correct. Yuo probably have multiple issues, and you'll need them all fixed before it will work.
I usually add msgbox statements to track down trouble areas.
Hi Gerry,
I started debugging this evening, more to come tomorrow.
I suppressed some functions and have to try some tests.
Good suggestion about the msgbox.
I'll keep in touch.
J.
PS: I had some corrections made by other sources and tested both () solutions.
It appears mach3 is having problems in the way you are using the Function and sub calls. I cleaned up all the obvious problems but still get errors on the function calls and sub calls. Not being a programmer can't be much more help.
I can get it to work BUT it sure is NOT a pretty way to do it. (so I am told(;-) ).
IF you can't get it worked out I will dive into it with you and see IF we can get it working. THERE are VB WIZARDS on here so hopefully they will chime in on this one.
I started to make many debugging tests and files to see what ans why.
Here is an example of code, partial since there's not all the functionalities.
If I add the Sub Main() and End at the end it's not working, syntax error, and if I don't, it's the same....
For clarity reasons I'll post another one message with other code related issues.
J.
Dim Z_TcPos As Integer
Dim ZUp_TcPos As Integer
'Flow sequence
End
Else
End If
'Call AirCyHome
'Call SpindleHome
Sleep (500)
While(IsMoving())'Do nothing while spindle is rotating
sleep(100)
Wend
' Show the user the state of the OUTPUT #1 input
If IsActive(OUTPUT1) Then
MsgBox "OUTPUT #1 output is active"
Else
MsgBox "OUTPUT #1 output is inactive"
End If
'Call Clamp
'Call LeastTravel
End If
Dim x As Integer
Dim CTPos As Integer 'Carrousel Tool Position Relative to OldTool Position
CTPos=0
Do Until IsActive(OEMTrig1)
Sleep(50)
Loop
For x=0 To CWPos
If IsActive(OEMTrig1) Then
x=x+1
Wend
End If
Next x
CTPos=x
Else
'Rotation CCW
Dim y As Integer
CTPos=0
Do Until IsActive(OEMTrig1) 'Turns the AC Motor On
Sleep(50)
Loop
For y=0 To CCWPos
y=y+1
Wend
End If
Next y
CTPos=y
End If
'Call Z_TcPosition
While(IsMoving())
Wend
While(IsMoving())
Wend
Z_TcPos=1 '1 quand en position pour Tool Change
'Call OldToolBack2TC
If Z_TcPos=1 Then
ActivateSignal(OUTPUT8)'Move carrousel via the air cylinder to reach the tool change position
Else
Call Z_TcPosition
End If
'Call Unclamp
If IsActive(INPUT2) Then'Sensor indicates that carrousel is at tool change position then
'Call ZUp_TcPosition
ZUp_TcPos=0 'var init
While(IsMoving())
Sleep(100)
Wend
While(IsMoving())
Wend
ZUp_TcPos=1
'Call Clamp
'Spindle Release
'Call AirCyHome
While (Not(AirCyHome))
Sleep(100)
Wend
Call SetCurrentTool( NewTool )
This is basically the same code than before, excepted that I use Functions rather than subs. It's a little bit better, I can have Z moves but nothing more.
Normally the OUTPUT1 should be activated but there's no actions, MsgBox confirms the statement.
Something strange occurs, my call sequence isn't respected, I can check that using more MsgBox.
If I try to use the functions inside the Main Sub, this is not working at all: Syntax error, this is also strange to me.
Jerome
Sub Main()
'Flow sequence
End
Else
End If
Call AirCyHome
MsgBox "Carrousel air cylinder position check"
Call SpindleHome
MsgBox "Spindle Home call"
Call Clamp
Call LeastTravel
Call OldToolBack2TC
Call Unclamp
Call Z_TcPosition
Call Clamp
Call AirCyHome
End Sub
ToolChangerPos = 0
ToolChangerPos = 1
TCMove = False
ToolChangerPos = -1
TCMove = True
End If
End Function
Function AirCyHome() As Integer
End Function
Function SpindleHome()
sleep(100)
Wend
'Show the user the state of the OUTPUT #1 input
Else
End If
Call ToolChangerPos
Call ZUp_TcPosition
Call OldToolBack2TC
Call Unclamp
Call ZUp_TcPosition
End Function
Function Z_TcPosition()
While(IsMoving())
Wend
While(IsMoving())
Wend
End Function
'Spindle Release
Function SpindleRelease()
End Function
Function OldToolBack2TC ()
If Z_TcPos=1 Then
else
Call Z_TcPosition
End if
End Function
Function Unclamp()
If IsActive(INPUT2) then'Sensor indicates that carrousel is at tool change position then
End If
End Function
Function Clamp()
End Function
Function ZUp_TcPosition()
While(IsMoving())
Sleep(100)
Wend
while(IsMoving())
wend
ZUp_TcPos=1
End Function
Function LeastTravel()
End If
call CW()
Else
call CCW()
End If
End Function
'Rotation CW
Function CW()
dim x as Integer
CTPos=0
Sleep(50)
loop
for x=0 to CWPos
x=x+1
Wend
End If
next x
CTPos=x
End Function
'Rotation CCW
Function CCW()
dim y as Integer
CTPos=0
Sleep(50)
loop
for y=0 to CCWPos
y=y+1
Wend
End If
next y
CTPos=y
End Function
Main
Hi Jerome
In just a couple of pages of code you've managed to make just about every error it's possible to make - so congratulations for that achievement at least. Just a FEW examples:
Incorrectly scoped variables. Variables that are assigned but never used. Variables that are used but never initialised. Functions that do NOTHING at all. Function return values discarded. Incorrect sub and function call syntax. Bizarre comparison of Boolean values. Inconsistent types. Explicit altering of loop control variables and MANY MANY more.
Be afraid - be very afraid - remember Skynet? you may have succeeded in creating the first toolchanger to exhibit artificial intelligence.
Start again - this code is beyond help. Explain the mechanics you have and what you want it to do and I'm sure you'll get help.
Ian
Hi Ian,
I remember Skynet, I'm one of their products... and you probably are John Connor :p
I need to be reprogrammed, without your intervention I'll destroy everything!
I changed the code to something more acceptable.
There are some "not yet used" variables, they should be used for security checks.
I understand why you're afraid...
Code update and comments will follow.
Jerome
I look forward to the challenge.... come tooled up ;)
Ian
