Mach Discussion => General Mach Discussion => Topic started by: ftec on May 02, 2012, 10:24:03 AM
Title: Emulating G31 probe input with keyboard, should it be possible?
Post by: ftec on May 02, 2012, 10:24:03 AM
Hi!
Should it be possible to emulate the proble input with keyboard for G31 probing? I have done some probe related coding which I would like to simulate before running it in the machine itself. I have set the letter 'P'' (80) as the hotkey and it turns the input led on as it should but it won't stop the movement.
/Risto
Title: Re: Emulating G31 probe input with keyboard, should it be possible?
Post by: BR549 on May 02, 2012, 10:40:24 AM
THe g31 cannot be emulated without the driver loaded and running. SO if you are running in simualtion mode (no driver loaded) then no.
Post by: ftec on May 02, 2012, 11:30:11 AM
Right, that's it!
/Risto
