Mach Discussion => General Mach Discussion => Topic started by: GytarrMann19 on April 18, 2012, 10:14:29 PM
Title: CV / Exact Stop issue
Post by: GytarrMann19 on April 18, 2012, 10:14:29 PM
Quick question-
My lathe runs better in exact stop mode, for whatever reason. I'm running a program now, and after running, the general config page reverts to CV mode. Set it to exact stop, run the program again, and it has again reverted to CV.
The only thing I'm doing different is using G32 to do some tapping. Does the G32 cycle automatically force Mach into CV?
Any idears?
Thanks!
Kevin
Title: Re: CV / Exact Stop issue
Post by: Hood on April 19, 2012, 02:38:20 AM
is there a G64 in your code?
Post by: GytarrMann19 on April 19, 2012, 12:56:08 PM
No sir.
Post by: Hood on April 19, 2012, 12:59:20 PM
If you attach the code and your xml I will see if I can replicate it.
Post by: GytarrMann19 on April 23, 2012, 02:46:11 PM
.tap and .xml attached
Thanks Hood!
Kevin
Post by: Hood on April 23, 2012, 03:25:23 PM
Seems to stay in G61 here, what are your macros? Could they be doing the change?
Post by: GytarrMann19 on April 23, 2012, 04:17:03 PM
The three macros at the beginning home the A, Z, X axes respectively. In MDI mode, none of the macros, including toolchange, nor the G32 cause Mach to switch to CV. So I don't know whats going on. Putting a few G61s in the part program seem to have fixed the problem anyways.
Kevin
