Mach Discussion => General Mach Discussion => Topic started by: NWar on April 16, 2012, 08:44:36 PM
Title: CV and 3 axis
Post by: NWar on April 16, 2012, 08:44:36 PM
I have recently downloaded the most current version of MACH3. I configure my settings to allow for CV, but as soon as I push the cycle/start button I am forced into G61, exact stop mode. Why?
I have tried the following:
-Stop CV at angle of 0-89 degrees, checked and unchecked
-CV distance tolerance, checked and unchecked. Various ranges of values
-Installed and reinstalled MACH and generated an entire new profile
-ABS vs. INC
I have tried the following for smoothing out motion:
-Sherline 1/2 pulse mode
-Step/Dir pulse values 0-5 in Motor Tuning
I have also borrowed a Smooth Stepper with absolutely no luck.
Thank you,
Title: Re: CV and 3 axis
Post by: Overloaded on April 16, 2012, 09:10:42 PM
How are you generating the GCode ?
Is there possibly a G61 in the prolog of the GCode from the CAM or whatever you are using to generate the GCode ?
Also, chech the Initialization string under Gen Config.
Might also post the code in queastion for evaluation.
Russ
Post by: NWar on April 17, 2012, 02:54:15 PM
Hi Russ,
Thank you for the reply sir. I am generating G-Code by using MasterCam X5 with a very stripped down post processor...lathe setting disabled. I will try checking the initializing string and possibly post the code as you recommended.
