Third party software and hardware support forums. => PoKeys => Topic started by: SScnc on March 31, 2012, 04:51:56 PM
Title: Is there a way...
Post by: SScnc on March 31, 2012, 04:51:56 PM
Is it possible to bring in sensor inputs from something like a proximity switch on the pokeys?
Title: Re: Is there a way...
Post by: NeoTO on April 02, 2012, 01:24:17 AM
What kind of output does this switch have?
If it has an analog output use the appropriate voltage attenuator first and connect it to the analog input pin (PoKeys has the limit of max. 3.3V on those pins).
If the switch has 4-20mA current output, use an appropriate resistor and connect it to the analog input pin similarly as above.
Give more details on the proximity switch to help you further.
Matevž, PoLabs
Post by: poppabear on April 03, 2012, 08:52:25 PM
Prox's usually run at 24vdc (sinking or sourcing), to interface to the PK, you could
do it through a Solid state relay, or if speed not real important, a standard relay.
Scott
