Mach Discussion => General Mach Discussion => Topic started by: replicaprops on January 04, 2007, 11:10:15 AM
I calculated my backlaash originally by clamping a micrometer in the work clamp and moving the table back and fourth a number of times to see what the difference was from actual micrometer readings and the mach 3 dro.
I settled on y= .009 and x =.007.
When im making circle cuts, the circle is not round. How do I use the shape of the circle to determine fine tuning the backlash?
I wouldn't. I would use an indicator. The best fix would be to tighten your machine. Do you have preloaded nuts? Ball screws or lead screws? I have not had very good luck with the backlash comp. in Mach. It will get the backlash to 0.000. It is good at that. My steppers just can't take the sudden move to do what Mach tells it to especially on an arc. I have not played with it in a while. There has been many revisions released since.
Post a picture of your circle.
I have single ball nuts
Here is the photo of the part I was engraving. All the curves are supposed to be smooth, and they look jagged.
Do you think it could be loose gibbs?
(http://www.replicaprops.com/images1/smallvillephotos/kk2.jpg)
Can you post your code? What Cam package did you write your code with?
I think your code is probably a bunch of point-point moves, no arcs. If you're Gibbs were extremely loose they could cause you grief. I doubt that is your problem.
I used visual mill to make the code. Do you know how to tell it to use arcs?
G00 G49 G40.1 G17 G80 G50 G90 G20
(Engraving)
T3 M6
G43 H3
M03 S2000
G00 Z0.2500
X1.3113 Y0.2551
G01 Z-0.0030 F7.3
X1.2239 F10.0
X1.1811 Y0.3425
X1.1346 Y0.2569
X1.1811 Y0.1813
X1.2257 Y0.2505
G00 Z0.2500
X1.3613 Y0.6483
G01 Z-0.0030 F7.3
Y0.3338 F10.0
G00 Z0.2500
X1.2585 Y0.2314
G01 Z-0.0030 F7.3
X1.2736 Y0.2322 F10.0
X1.2854 Y0.2417
X1.2893 Y0.2563
X1.2839 Y0.2705
X1.2712 Y0.2788
X1.2561 Y0.2780
X1.2443 Y0.2685
X1.2403 Y0.2538
X1.2457 Y0.2397
X1.2585 Y0.2314
G00 Z0.2500
X2.0561 Y2.3344
G01 Z-0.0030 F7.3
X2.0293 Y2.3586 F10.0
X2.0015 Y2.3740
X1.9765 Y2.3784
X1.9577 Y2.3712
X1.9485 Y2.3532
X1.9505 Y2.3280
X1.9628 Y2.2990
X1.9842 Y2.2697
X2.0109 Y2.2456
X2.0384 Y2.2303
X2.0634 Y2.2257
X2.0821 Y2.2330
X2.0913 Y2.2509
X2.0895 Y2.2763
X2.0772 Y2.3054
X2.0561 Y2.3344
G00 Z0.2500
X1.8939 Y2.2089
G01 Z-0.0030 F7.3
X1.9205 Y2.1848 F10.0
X1.9480 Y2.1695
X1.9730 Y2.1649
X1.9918 Y2.1722
X2.0011 Y2.1902
X1.9994 Y2.2157
X1.9872 Y2.2449
X1.9662 Y2.2740
X1.9413 Y2.2959
X1.9131 Y2.3113
X1.8867 Y2.3169
X1.8673 Y2.3104
X1.8583 Y2.2922
X1.8606 Y2.2666
X1.8731 Y2.2375
X1.8939 Y2.2089
G00 Z0.2500
X2.0094 Y2.4022
G01 Z-0.0030 F7.3
X1.8515 Y2.4017 F10.0
X1.8318 Y2.1465
X2.0958 Y2.1399
X2.1185 Y2.2811
X2.0094 Y2.4022
G00 Z0.2500
X2.2004 Y1.9613
G01 Z-0.0030 F7.3
X2.2618 Y2.1334 F10.0
X2.0768 Y2.0871
X2.0313 Y1.9250
X2.1899 Y1.9519
X2.1463 Y1.9127
X2.2422 Y1.8062
X2.3427 Y1.8967
X2.2468 Y2.0032
X2.2004 Y1.9613
G00 Z0.2500
X2.1878 Y1.8522
G01 Z-0.0030 F7.3
X2.1775 Y1.8570 F10.0
X2.1667 Y1.8533
X2.1619 Y1.8429
X2.1656 Y1.8321
X2.1759 Y1.8273
X2.1868 Y1.8310
X2.1916 Y1.8414
X2.1878 Y1.8522
G00 Z0.2500
X1.4762 Y0.3260
G01 Z-0.0030 F7.3
X1.4693 Y0.3220 F10.0
Y0.3140
X1.4762 Y0.3100
X1.4831 Y0.3140
Y0.3220
X1.4762 Y0.3260
G00 Z0.2500
X1.3580 Y0.3254
G01 Z-0.0030 F7.3
X1.3112 Y0.2372 F10.0
X1.3583 Y0.1627
X1.4056 Y0.2372
X1.3580 Y0.3254
G00 Z0.2500
X1.3891 Y0.5795
G01 Z-0.0030 F7.3
X1.3851 Y0.5931 F10.0
X1.3749 Y0.6028
X1.3612 Y0.6062
X1.3475 Y0.6028
X1.3372 Y0.5931
X1.3333 Y0.5795
X1.3373 Y0.5659
X1.3475 Y0.5562
X1.3612 Y0.5528
X1.3749 Y0.5562
X1.3851 Y0.5659
X1.3891 Y0.5795
G00 Z0.2500
X1.5267 Y0.4903
G01 Z-0.0030 F7.3
X1.5233 Y0.5218 F10.0
X1.5137 Y0.5512
X1.4984 Y0.5777
X1.4782 Y0.6008
X1.4537 Y0.6199
X1.4256 Y0.6343
X1.3946 Y0.6434
X1.3612 Y0.6466
X1.3278 Y0.6434
X1.2968 Y0.6343
X1.2687 Y0.6199
X1.2442 Y0.6008
X1.2240 Y0.5777
X1.2087 Y0.5512
X1.1991 Y0.5218
X1.1957 Y0.4903
X1.1991 Y0.4588
X1.2087 Y0.4295
X1.2240 Y0.4029
X1.2442 Y0.3798
X1.2687 Y0.3607
X1.2968 Y0.3463
X1.3278 Y0.3372
X1.3612 Y0.3340
X1.3946 Y0.3372
X1.4256 Y0.3463
X1.4537 Y0.3607
X1.4782 Y0.3798
X1.4984 Y0.4029
X1.5137 Y0.4295
X1.5233 Y0.4588
X1.5267 Y0.4903
G00 Z0.2500
X0.1359 Y1.8229
G01 Z-0.0030 F7.3
Y1.6935 F10.0
X0.2992
Y1.8229
X0.1359
G00 Z0.2500
X0.1994 Y1.8592
G01 Z-0.0030 F7.3
X0.2992 F10.0
Y1.8826
X0.1359
Y1.8592
X0.1756
X0.1793 Y1.8680
X0.1873 Y1.8713
X0.1939 Y1.8692
X0.1991 Y1.8616
X0.1994 Y1.8592
G00 Z0.2500
X0.1543 Y1.6684
G01 Z-0.0030 F7.3
X0.1518 Y1.6751 F10.0
X0.1451 Y1.6780
X0.1384 Y1.6751
X0.1359 Y1.6684
X0.1384 Y1.6617
X0.1451 Y1.6588
X0.1518 Y1.6617
X0.1543 Y1.6684
G00 Z0.2500
Y1.6367
G01 Z-0.0030 F7.3
X0.1518 Y1.6434 F10.0
X0.1451 Y1.6459
X0.1384 Y1.6434
X0.1359 Y1.6367
X0.1384 Y1.6300
X0.1451 Y1.6271
X0.1518 Y1.6300
X0.1543 Y1.6367
G00 Z0.2500
X0.2996 Y1.6408
G01 Z-0.0030 F7.3
X0.1722 F10.0
Y1.6325
X0.2996
Y1.6408
G00 Z0.2500
X0.2157 Y1.6797
G01 Z-0.0030 F7.3
X0.1722 F10.0
Y1.6563
X0.2996
Y1.6797
X0.2374
X0.2340 Y1.6722
X0.2265 Y1.6692
X0.2190 Y1.6722
X0.2157 Y1.6797
G00 Z0.2500
X0.1476 Y1.5502
G01 Z-0.0030 F7.3
X0.2274 Y1.4997 F10.0
X0.3359 Y1.5582
X0.2274 Y1.6154
X0.1476 Y1.5653
Y1.5974
X0.1359
Y1.4726
X0.1476
Y1.5502
G00 Z0.2500
X0.2954 Y1.5853
G01 Z-0.0030 F7.3
X0.2979 Y1.5786 F10.0
X0.3046 Y1.5757
X0.3113 Y1.5786
X0.3142 Y1.5853
X0.3113 Y1.5920
X0.3046 Y1.5945
X0.2979 Y1.5920
X0.2954 Y1.5853
G00 Z0.2500
X0.1722 Y1.4417
G01 Z-0.0030 F7.3
Y1.3143 F10.0
X0.1827
Y1.4417
X0.1722
G00 Z0.2500
X0.2303 Y1.3799
G01 Z-0.0030 F7.3
X0.2176 Y1.3741 F10.0
X0.2073 Y1.3644
X0.2004 Y1.3516
X0.1981 Y1.3373
X0.2011 Y1.3210
X0.2107 Y1.3072
X0.2244 Y1.2980
X0.2407 Y1.2947
X0.2570 Y1.2980
X0.2708 Y1.3072
X0.2800 Y1.3210
X0.2833 Y1.3373
X0.2810 Y1.3516
X0.2741 Y1.3644
X0.2638 Y1.3743
X0.2512 Y1.3799
X0.2638 Y1.3860
X0.2741 Y1.3961
X0.2810 Y1.4089
X0.2833 Y1.4229
X0.2800 Y1.4396
X0.2708 Y1.4529
X0.2570 Y1.4625
X0.2407 Y1.4655
X0.2244 Y1.4625
X0.2107 Y1.4529
X0.2011 Y1.4396
X0.1981 Y1.4229
X0.2003 Y1.4089
X0.2069 Y1.3961
X0.2173 Y1.3860
X0.2303 Y1.3799
G00 Z0.2500
X0.1994 Y1.2271
G01 Z-0.0030 F7.3
X0.2992 F10.0
Y1.2504
X0.1359
Y1.2271
X0.1756
X0.1793 Y1.2358
X0.1873 Y1.2392
X0.1939 Y1.2371
X0.1991 Y1.2295
X0.1994 Y1.2271
G00 Z0.2500
X0.1777 Y1.1770
G01 Z-0.0030 F7.3
X0.1806 Y1.1703 F10.0
X0.1873 Y1.1674
X0.1944 Y1.1703
X0.1973 Y1.1770
X0.1944 Y1.1836
X0.1873 Y1.1866
X0.1806 Y1.1836
X0.1777 Y1.1770
G00 Z0.2500
X0.1359 Y1.2012
G01 Z-0.0030 F7.3
X0.2992 F10.0
Y1.2141
X0.1359
Y1.2012
G00 Z0.2500
Y1.2759
G01 Z-0.0030 F7.3
Y1.2630 F10.0
X0.2992
Y1.2759
X0.1359
G00 Z0.2500
Y1.0229
G01 Z-0.0030 F7.3
X0.2992 F10.0
Y1.1527
X0.1359
Y1.0229
G00 Z0.2500
X0.1994 Y0.9870
G01 Z-0.0030 F7.3
X0.1973 Y0.9804 F10.0
X0.1897 Y0.9751
X0.1830 Y0.9758
X0.1765 Y0.9824
X0.1756 Y0.9870
X0.1359
Y0.9636
X0.2992
Y0.9870
X0.1994
G00 Z0.2500
X0.3363 Y0.9031
G01 Z-0.0030 F7.3
X0.3334 Y0.9102 F10.0
X0.3267 Y0.9127
X0.3201 Y0.9102
X0.3171 Y0.9031
X0.3201 Y0.8964
X0.3267 Y0.8935
X0.3334 Y0.8964
X0.3363 Y0.9031
G00 Z0.2500
X0.1359
G01 Z-0.0030 F7.3
X0.1384 Y0.8964 F10.0
X0.1455 Y0.8935
X0.1522 Y0.8964
X0.1551 Y0.9031
X0.1522 Y0.9102
X0.1455 Y0.9127
X0.1384 Y0.9102
X0.1359 Y0.9031
G00 Z0.2500
X0.2048 Y0.9072
G01 Z-0.0030 F7.3
X0.1988 Y0.9123 F10.0
X0.1922 Y0.9120
X0.1871 Y0.9069
Y0.8995
X0.1922 Y0.8942
X0.1988 Y0.8939
X0.2048 Y0.8993
Y0.8580
X0.2917
Y0.9498
X0.2048
Y0.9072
G00 Z0.2500
X1.4384 Y0.2891
G01 Z-0.0030 F7.3
X1.5122 F10.0
Y0.2188
X1.4384
Y0.2891
G00 Z0.2500
X1.4834 Y0.2090
G01 Z-0.0030 F7.3
X1.4800 Y0.2150 F10.0
X1.4731
X1.4697 Y0.2090
X1.4731 Y0.2031
X1.4800
X1.4834 Y0.2090
G00 Z0.2500
X1.4762 Y0.1626
G01 Z-0.0030 F7.3
X1.4831 Y0.1666 F10.0
Y0.1746
X1.4762 Y0.1785
X1.4693 Y0.1745
Y0.1666
X1.4762 Y0.1626
G00 Z0.2500
X2.6245 Y1.8850
G01 Z-0.0030 F7.3
X2.6239 Y0.8395 F10.0
X1.8844 Y0.1000
X0.8389 Y0.1007
X0.1000 Y0.8401
X0.1006 Y1.8857
X0.8401 Y2.6251
X1.8857 Y2.6245
X2.6245 Y1.8850
G00 Z0.2500
G00 Z1 M5 M9 M30
Yeap, that is point to point. No I or J moves. Can you send me your art in a dxf format? Does visual code have an option for arc fitting vectors?
I did the original design within visual mill, so its in the visual mill native format. There is no export option on visual mill to export the curves.
I made it with a font and curves then just ran the code as engraving.
Im going to have to check with the Visual mill user group to see if the code can be generated with arcs.
The problem has been solved. It was indeed the Arc command. In Visual mill there is a button under machining preferences that reads output arcs as linear segments. By default it is checked. I unchecked it and thenran my backlash tests again. The backlash did need to be adjusted slightly. Thanks, hope someone else finds this usefull in the future.
