Mach Discussion => General Mach Discussion => Topic started by: bob b on March 25, 2012, 07:24:16 AM
when i tried to use power feed X&Y a letter box comes up and says, if you name is not on this list you cannot use ! you must purchase license , and Jeff sandstorm version r3.043022 is all i see with a bunch of other names flashing across screen. I have added latest version and purchased wizard license, do i have to purchase some thing else? I have used the write program successfully and had no problem .
Assume your a Mach license was part of the bundle that came with your machine. Suggest you contact the seller to find out what's wrong.
