Mach Discussion => General Mach Discussion => Topic started by: jeffhead on March 12, 2012, 02:26:13 PM
Just got a new computer and I have been using mach3 for 4 or 5 yrs now. So I loaded mach3 version R3.043.022 and the lazycam that comes with it. Everything works great except when I post the g-code from lazycam it does not automatically load into mach3 I have to load it manually from the mach3 g-code folder. So my question is how do I fix this problem or is this even a problem?? Thanks for any help with this. ;D
:)Hi !
4 to 5 years makes you a veteran ! :D
Do you have this checked ?
First things first.
Russ :)
The only time I had the problem you described is when i did not install LC along with Mach. ie; you install Mach and then come back and install LC at later time.
What version of Windows are you using?
