Mach Discussion => General Mach Discussion => Topic started by: marcel beaudry on January 03, 2007, 11:17:52 AM
Title: radius
Post by: marcel beaudry on January 03, 2007, 11:17:52 AM
Hello i am having problem with my lathe and the radius function it was working fine until yesterday ,the g2 and g3 are now reversed ,the radius are now barrel shaped ,when i put an indicator on my axes they move as they should  .100 on z axis and .050 on x axis .in the motor tuning the x and z have the same step per and the same velocity. when i write the following code g0 xo zo then g2 x.250 z-.875 r.437 the tool when it reaches the halfway point the x axis goes to 1.008 inch and the z axis goes .437 hence my problem any reply would be helpful thank you Marcel
Title: Re: radius
Post by: Brian Barker on January 03, 2007, 11:54:43 AM
There is a reversal of arcs on the Ports and pins page :) that should do it
Brian
Title: Re: radius
Post by: marcel beaudry on January 03, 2007, 12:21:39 PM
Thanks Brian that is one part of the problem fixed now for the diameter why woud the diameter of the sphere be 1.008 when the program told to have a radius of .437 (yes the tool was adjusted in the x axis)
marcel
Title: Re: radius
Post by: Graham Waterworth on January 03, 2007, 01:28:50 PM
You can not have a radius bigger than half the diameter of the part with a Z move that is past the center of the rad.
if you want a .250 dia ball end on your bar you would enter :-
g20 g40 g90
g00 x0 z0
g03 x.250 z-.125 r.125
g01 z-.500
x1.
m30
Graham.
Title: Re: radius
Post by: marcel beaudry on January 03, 2007, 02:38:30 PM
Graham
just imagine an .250 cylinder attached to a .875 ball that is what i am trying to do.
Marcel
Title: Re: radius
Post by: Graham Waterworth on January 03, 2007, 03:02:08 PM
You can't do it like that, you can only do it in 2 moves, like this :-
G00 X0 Z0
G03 X.875 Z-.4375 R.4375 F1.
G03 X.250 Z-.8568 R.4375
G01 Z-1.
G00 X1.
M30
The problem you will have is getting the tool down the back of the ball.
Graham.
Oops working to 4 places not 2
Title: Re: radius
Post by: marcel beaudry on January 03, 2007, 03:19:46 PM
Graham
Thank you very much for your quick reply i will try it tonight my tool is .010 wide the precision of the ball does not have to be a perfect.thank you again for your time.
Marcel
Title: Re: radius
Post by: Graham Waterworth on January 03, 2007, 03:26:21 PM
If you set the offset to the front edge of the tool then use this bit of code :-
G00 X0 Z0
G01 Z-.4475
G03 X.250 Z-.8668 R.4375
G01 Z-1.
G00 X1.
M30
This will make the ball correct using the back edge of the tool on the back of the ball.
Graham.
Title: Re: radius
Post by: marcel beaudry on January 03, 2007, 03:46:19 PM
Thank again for all the information
Marcel
Title: Re: radius
Post by: Graham Waterworth on January 03, 2007, 03:46:49 PM
.010" wide sound very thin for a parting/grooving tool for this job, is it not .100"
If it is .100" then this is the code :-
G00 X0 Z0
G01 Z-.5375
G03 X.250 Z-.9568 R.4375
G01 Z-1.
G00 X1.
M30
Graham.
Title: Re: radius
Post by: marcel beaudry on January 03, 2007, 04:13:05 PM
Graham
the tool is for turning a blank of wood to make ornamental turnings
Marcel
Title: Re: radius
Post by: Graham Waterworth on January 03, 2007, 04:30:05 PM
OK,  panic over!  :)
Graham.
Title: Re: radius
Post by: marcel beaudry on January 04, 2007, 09:36:07 AM
Graham
works like a charm, thanks you
you have a private message
Marcel
Title: Re: radius
Post by: dfurlano on January 04, 2007, 01:16:37 PM
Marcel,
You do ornamental turning?  What equipment do you use?  Can you post a photo of something you have turned?
Dan.
Title: Re: radius
Post by: Chaoticone on January 04, 2007, 02:19:32 PM
Graham The Great (Gcode Guru), strikes again!  ;D
Title: Re: radius
Post by: marcel beaudry on January 04, 2007, 05:21:58 PM
these are example of ornamental turning i do in wood and in brass
Marcel
Title: Re: radius
Post by: marcel beaudry on January 04, 2007, 05:29:04 PM
here are some in brass and wood
Marcel
