Mach Discussion => General Mach Discussion => Topic started by: PCH on March 09, 2012, 09:31:36 AM
Title: Running circle wizard
Post by: PCH on March 09, 2012, 09:31:36 AM
keep get error messages in the circle wizard. No matter what I change I get the Vb error or radius from end of arc differs from radius on line 5
I need a tutorial on these wizards.  >:(
Title: Re: Running circle wizard
Post by: Overloaded on March 09, 2012, 09:45:33 AM
The wizard spits out code in Inc. IJ mode.
Try G91.1 at the beginning of the file, or select Inc IJ in Gen Config.
Russ
Post by: Milhobs001 on August 01, 2018, 08:15:07 PM
Hello i am having problems with cutting circle pockets. Can someone please help me. I need to show you what is happening, dont know how to upload a photo yet.
Post by: Milhobs001 on August 01, 2018, 08:30:32 PM
Dont know if it worked but i attached a photo. So anyway whats happening in when i use the mach3 wizard for circle pocket ( 15mm dia, 4mm deep) when the tool does it frist cut all goes well. When it dose the second cut it start to go in a ovel shape, but it does it on all cuts. I set it to cut a 1mm step down.
Post by: Tweakie.CNC on August 02, 2018, 12:41:47 AM
I would suspect that the problem is mechanical, maybe a loose coupling ?
Check that you are not loosing steps - does the machine return eaxctly to the zero position after it has finished making the oval pockets ?
