Mach Discussion => General Mach Discussion => Topic started by: zeeschuim on March 03, 2012, 10:59:00 AM
strange behaviour with the OD fillet 2 from the lathe wizards?
Post a screenshot of the settings you have entered please.
What lathe mode are you using..... diameter or radius ?
Some of the wizards don't work in both modes if memory is correct and don't know which ones they are.
I am using diameter
I cant get it to work correctly either,I have to reverse the arc direction for it to look ok with my xml. Looks like its just another thing that doesnt work correctly in Turn :(
I altered the wizard to put out G3's rather than G2's and it works ok form me now.
If you can attach your xml I will have a look and see if I can find the problem with your setup.
here it is
Zeeschium,
I don't know what you did to accomplish what you posted in reply #0.
( could be where you defined X axis position before you ran the wizard )
Using your xml and also your inputs I get what you get in reply #3.
Compared the two different gcodes and looks like you were using different inputs or even config for reply #0.
Using your xml I too get it working fine.
I get the strange behaviour when I run f the file.
Hood: did you run the file?
Try this,
I ran the file using your xml, using the standard screen, and code as posted from the wizard and had no problem.
Can you post a screen shot of you manual & cycle screen ?
Yes ran it, heres a screenshot.
I think you may be having a version issue, are you using a development version of Mach?
here they are
Yes I am almost certain you have a development version loaded, they are screwed up for turn, nothing new there ;)
your screenshot shows also a horizontal and a vertical line straight trough your workpiece?
Not through the workpiece I dont think, that will be at the start position
The wizard is very wastefull of moves doing complete arcs of 90 degrees, the firt load of cuts will be very small but it will still move the complete 90 degrees before the next pass, only when the fillet is nearing completion will the full 90 be actually cutting.
Put a larger number for your clearance and you will get it further away, still the same wastefull moves but will look better on your screen.
Still back at 3.042.033 here. Now I know why :D
Been fooling around for the last two hours trying to screw it up and couldn't accomplish what zee.... was getting if i tried. ;D
Thanks Hood,
Ok Hood, I download and installed the .....22 version and I gave it a clearence of 10mm and now it is looking good!
thanks for your help!
Ok no probs, clearance of 1 would still work, just would look as if its cutting through material when its not.
Hmm ...........maybe ver 059 will fix everything in lathe >:D
Afraid not Rich.
Supposedly Rev4 will but only after Mill etc has been done so ..... well I have had lots of promises before ;)
To be fair to Brian the majority of users are mill/router and the OEMs are I would imagine all Mill/Router so he has to do that.
Turn very occasionally gets looked at when the shouting gets loud enough but afraid one thing gets fixed and another breaks. It is because of that that this issue is seen, it was a fix for softlimits that screwed up the toolpath, may be fixed in the very latest Dev version, dont know never tried it to see.
