Mach Discussion => General Mach Discussion => Topic started by: kolias on February 29, 2012, 08:45:52 PM
Title: New Build
Post by: kolias on February 29, 2012, 08:45:52 PM
I plan to make a new CNC, approx. 36”x 36” cutting area with a moving table and made with 8020 aluminum members.
The drives will be Gecko but don’t know yet which model
The 3 speed spindle will be from http://www.cnconabudget.com/
And the z axis similar to http://k2cnc.com/
I’m looking to see if I can use some kind of a linear system for all axes but in Canada they are not easy to find or the ones I find from US, the shipping / duties cost is very high. Maybe I will go to ACME 1/2"-10, 5 start.
I wonder if anyone has any suggestions
Title: Re: New Build
Post by: kolias on August 27, 2012, 12:29:42 AM
Finally my new build was made with 1/2" thick aluminum plate / flatbar and other changes and here are some pics.
Cutting area is approx. Y=36”, X-26”, Z=8”. The gantry vertical pcs are temporary and new pcs will be cut in an “S” shape when the cnc is ready. Also the plate on the pushbuttons station is temporary and a new plate will be cut from 1/8” aluminum and all buttons will be engraved.
The rails and ballscrews are from China and all electronics / Taig spindle and Sherline motor / VS unit from Soigeneris
The table top will be either 1/4" tooling plate or aluminum plate
I’m at the final stages of wiring and hoping to start the machine sometimes this week
Post by: kolias on August 27, 2012, 12:32:29 AM
More pics
Post by: kolias on August 27, 2012, 12:34:43 AM
Some more
Post by: Tweakie.CNC on August 27, 2012, 02:21:05 AM
Truly excellent build Nicolas - you have put a lot of work and experience into this project. My congratulations.
Post by: Sam on August 27, 2012, 11:53:49 PM
My thoughts exactly. You sure have came a long way in the past few months. Most people throw in the towel before they accomplish what you have. Congratulations, and thank you for sharing with us.
Post by: Hood on August 28, 2012, 02:09:58 AM
Looks like you have caught the CNC disease :)
Looking great.
Post by: kolias on August 28, 2012, 07:55:24 AM
Yesterday I got the power on for the 1st time and I got the green light on the G540
I was setting up Mach3 and about 10 minutes latter I smelled burning wires and noticed smoke coming out from the A axis DB9 connector and I shut it down.
I used the EZ-G540 DB9 connectors and after taking apart the faulty connector I noticed that one of the screws holding the 2 pcs together pinched one wire and sort it out. Don’t know why it took about 10 minutes to sort it out.
What is an alternate way to connect the motors to the G540?
Post by: kolias on August 30, 2012, 02:57:53 PM
I replaced the connectors to the G540 with regular DB9 connectors and now the machine works good. Never used the G540 before and have these questions.
When I press the E-stop, nothing happens on the Mach screen, but the light on the G540 goes red and after a few seconds turns off and at this point Mach says and E-stop is active. Is this normal?
What is the CV Mode on the main Mach screen which is now highlighted?
Are any typical / normal settings for the motors with G540
Post by: Hood on August 30, 2012, 04:33:37 PM
Cant help with the G540 questions but CV mode is constant Velocity mode (G64) and it means that the code will blend from line to line. If you have slow acceleration then you may get corner rounding otherwise it is the setting that is normal to use. The other is Exact Stop (G61) and that means your axis will decelerate to a stop at the end of a line of code before it accelerates for the next.
Title: New Build
Post by: Fastest1 on August 30, 2012, 04:59:22 PM
You mention you replaced the DB9's from the EZ G540 db9's? Did you install a current set resistor? Is your estop connected to the G540? Not just an estop thru Mach is it? I personally like a contactor but some act like smaller machines don't need it. Due you have the charge pump enabled? This will stop any motion from occurring if the computer is not on or Mach isn't running though the machine is on IIRC.
Post by: kolias on August 30, 2012, 05:58:46 PM
Thanks all  for the help
Yes I have the right resistor for each DB9 and all motors run good but have to tune them properly
The E-stop is connected to G540 as it should and it works, I just don’t get the interface I’m used to with Mack (pressing E-stop Mack needs reset)
Charge pump is also enabled
Title: New Build
Post by: Fastest1 on August 31, 2012, 06:22:43 AM
You are not having to press the reset button within Mach after physically pressing an Emergency switch hooked directly to your G540? What version of Mach are you running? Have you updated it lately and possibly installed a version that might have a bug?
Post by: Hood on August 31, 2012, 12:18:45 PM
Do you have an input pin set in Mach for the E-Stop? Does the G540 pass that to Mach?
Post by: kolias on September 04, 2012, 08:04:34 AM
My Mach version is R3.043.022 and all is fine now after I downloaded the XML from Gecko; this fixed the problem with the E-stop
BTW why I don’t get an email notification from my post although I have checked the "Notify me of replies" button?
Post by: kolias on September 04, 2012, 08:28:41 AM
The top of my table (that’s where I will put my pcs for cutting) is 41.5”x 27.5” and I plan to cover it with one of these materials:
3/8” Thick MIC-6 Tooling Plate, $630.00
3/8” Thick Aluminum Plate, $390.00
1/4" Thick Aluminum Plate, $265.00
The first two are too expensive for me and I’m thinking to go with the 1/4" Aluminum plate. The span is not that big and if I put a longitudinal support underneath I feel that’s it should be ok.
What is your opinion?
