Mach Discussion => General Mach Discussion => Topic started by: dwneumann on February 24, 2012, 12:43:59 AM
Title: override tool change auto zero macro?
Post by: dwneumann on February 24, 2012, 12:43:59 AM
During a tool change how do I override the invoking of the auto-zero macro when inserting a tool that won't contact the probe plate properly (e.g. a slitting saw) or when the cutting tool is offset from the spindle enough to miss the probe plate altogether  (e.g. single point flycutter, indexable boring bar, etc.) ?
thanks...
Title: Re: override tool change auto zero macro?
Post by: Hood on February 24, 2012, 01:58:59 AM
The AutoZero you mention is not a standard part of Mach. That means it is likely part of your M6macro which has been customised by you or your supplier so you will need to alter it.
