G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: sandcrab on February 12, 2012, 03:58:26 PM
I am cutting the cranckase to rough size after mounting the bearing caps and ended up copying and pasting in the edit G code screen. I know there is a method for repeating a cycle, but haven't found it yet. Most of the wizards waste the motion since I already have the cavity and just need to face the caps and remove a little excess casting material. A typical first pass is
Z.6
X.5 Y-2
X2.5
Y-3.5
X.5
Y2 Z.5
Each time around .1" deeper cut feeding at 7 ipm. I have started out running everything ablolute from the 0,0 point established on the block, but for the rough machining the pockets that were the same size could be done as G91.
The block is in the show and tell section and I'll post a current shot.
the
You can do something like this :-
O0001
(STANDARD SETUP LINES)
G00 G90 X0 Y0
Z.1
G01 Z0 F7.
M98 P2 L10 (WILL LOOP 10 TIMES E.G. 1" DEEP)
G90
G00 Z1.
M30
O0002
G91
G01 Z-.1 F7.
G90
X.5 Y-2
X2.5
Y-3.5
X.5
Y2.
X0 Y0 (BACK TO START POINT)
M99
Graham
Thanks Graham I'll run it in one of the pockets later today.
