Third party software and hardware support forums. => Third party software and hardware support forums. => Topic started by: machining fool on February 10, 2012, 02:43:34 PM
I am going to build a cnc router. I have bought two Adept linear slides that are powered with brushless dc servo motors. I have contacted Granite, and they say that their drives and breakout board will work with these servos. My question is will these be compatible with Mach3? I would appreciate any input I can get. Thanks, machining fool, Robert Brown. These Granite drives 160 volts are only 243. euro, I will have to find out how much in US.
Machining Fool-
You can use these with mach. I would recomend using there breakout board, it is alot easier to install.
If you have any questions just ask
Steve
Thank you for your reply, as you can see I am learning as I go along. I have another question. I understand that Mach does not support closed loop, such as absolute position, does EMC2? I think that is the name of it. Thanks. These servos have 2000/step encoding and I would like to have accurate position sensing. Thanks again. Bob.
I am not sure about emc2.
Steve
