Mach Discussion => General Mach Discussion => Topic started by: Alejandrog on February 01, 2012, 01:49:46 AM
Hi guys,
I have a very strange problem here. I was running my CNC machine this morning and it was running fine. I turned it off for about 4 hours and when I came back and tried to run a cut the spindle would simply not work at all. all the axis move perfectly and I even plugged the spindle directly to check if it's running and it's fine, but it's not running from mach, either if I try to make it run or if I run a program.
Can someone help me please?
does the yellow light flash on the screen, when you activate the spindle
Yes, it flashes like if it was running normally but the router doesn't start. I checked the config a couple of times, turned off and on the machine and pc and still same problem.
What can I do?
what powers the spindle
The Cnc has a control box which is connected to the pc but it only has the on/off buton
is there a seperate fuse in the control box for the spindle?
Does the spindle have speed control?
You can change the speed but only trough mach3 and I even tried to increase it to the max or min and nothing happens. It's actually the only part that is not responding, all the axis move perfectly
ok, there are normally two functions required to run the spindle.
1. A relay will be energised to enable the spindle.
2. a signal is sent to an analogue board to vary the speed.
start the spindle in mach and listen for the relay activation.
You really need to get in the control box to see what type of spindle controller you have. A pic of the insides will help.
I opened the control box, but the machine is practically new! less than a month old! so everything looks very new.
this is my machine
http://i00.i.aliimg.com/img/pb/566/899/410/410899566_149.jpg
this is the box from behind
http://i01.i.aliimg.com/img/pb/711/297/396/396297711_781.jpg
and the box inside
http://alejooz.blogspot.com.au/2012/02/blog-post.html
It's fixed. for some reason I thought of reinstalling mach3 and it actually worked out well.
My problem with mach is that i have to use the version 1 wich the machine came with, if I install the version 3 I can't open big gcode files cause I don't have a licence for the newer version and I don't know what licence this machine came with but runs my files well
Thanks for all the help!
If you have a licence for an older version of Mach and it is saying it is not valid with Mach3 then it would seem it is a pirate licence you have as the original licence that came with the very first versions of Mach are valid for all versions.
