Third party software and hardware support forums. => LazyTurn => Topic started by: jchronister on January 31, 2012, 06:06:52 AM
Title: Anyone successful creating code in Lazyturn in Diameter Mode?
Post by: jchronister on January 31, 2012, 06:06:52 AM
I've seen a few posts about finish passes not being in diameter mode, but no answers. I'm using an older Denford Microturn lathe that's in diameter mode. No answers about how to switch it to radius mode. Easyturn would be a great solution for my classroom, but can only get diameter mode to work with rough pass- not the finish pass. I could have the kids double the X coords in the code, but students would miss a number here or there. It would be great to know if anyone has had success generating both passes in diameter mode.
Thanks much,
Jim
Title: Re: Anyone successful creating code in Lazyturn in Diameter Mode?
Post by: RICH on January 31, 2012, 11:44:21 AM
I am not aware of such a problem.
You can change from diameter to radius mode in both Lazyturn and Mach3 turn.
Your mode should be the same from the DFX, to Lazyturn setup, to export of the code into Mach3 turn.
I would suggest you have a read of the Lazyturn Manual which can be found in Members Docs.
Post your dxf file which is drawn based on diameter.
Post by: jchronister on January 31, 2012, 12:57:57 PM
Thanks for the reply Rich,
It's good to know that it should work. I've followed the manual for generating DXF files (except I've used an AutoCAD 2004 ACSII dxf since is seems to work well for all models I've tried). I must have overlooked where the DXF can be saved in diameter mode. I thought it was just a profile, saved with the origin at 0,0 from my AutoCAD or ProgeCAD program, the taken into Lazyturn.
I will look into the manual more.
I don't have a problem with the rough pass- that comes out in diameter mode. The final pass will always generate in radius mode.
Post by: jchronister on January 31, 2012, 03:14:00 PM
Hope you're still watching this Forum Rich,
I've resaved my dxf file. For some reason, I can't export as a binary v 12 dxf that Lazyturn likes, but it likes a v12 ascii dxf. Same results as saving it as a 2004 file. I've attached that file. Following the instructions in the manual, I don't see any options while saving the dxf file about diameter mode.. just a drawing file. When I open it in Lazyturn, I have it set to diameter mode in the options pull down. Select my tool and generate the rough pass, then generating the fine pass. The diameter mode is never de-selected. When looking at the posted code, The rough pass is in diameter settings and the fine pass is in radius settings (need to be doubled). What am I missing? If I could switch my lathe to radius mode, this wouldn't be a problem- just do everything as a radius. The problem is that Denford doesn't support the older machines and the forums haven't helped. Love to get Lazyturn working. I know I could always have the kids go through and double the Xs on the second pass, but that could be a disaster with some of their math skills :-)
I've attached my DXF and here's the generated code. It is a 1" diameter dowel used for a rocket noecone.- Thanks
( LazyTurn Alpha 1.1 )
(Tuesday, January 31, 2012 )
(Ogive Nose Cone)
 (--------------ToolPath 1 of 2 )
(Change to Tool: .0625 cutter        -R0.0010-IC0.0440 )
T0000
S3000 F80.00 M3
G0Z0.1111
G0X1.0420
G1 F50.0000  X1.0200
 X0.9800
 F80.0000  Z-2.3750
G0  X1.0000
 Z0.1111
G1 F50.0000  X0.9800
 X0.9600
 F80.0000  Z-2.3750
G0  X0.9800
 Z0.1111
G1 F50.0000  X0.9600
 X0.9400
 F80.0000  Z-2.3750
G0  X0.9600
 Z0.1111
G1 F50.0000  X0.9400
 X0.9200
 F80.0000  Z-2.3750
G0  X0.9400
 Z0.1111
G1 F50.0000  X0.9200
 X0.9000
 F80.0000  Z-2.3750
G0  X0.9200
 Z0.1111
G1 F50.0000  X0.9000
 X0.8800
 F80.0000  Z-1.3292
G0  X0.9000
 Z0.1111
G1 F50.0000  X0.8800
 X0.8600
 F80.0000  Z-1.2238
G0  X0.8800
 Z0.1111
G1 F50.0000  X0.8600
 X0.8400
 F80.0000  Z-1.1450
G0  X0.8600
 Z0.1111
G1 F50.0000  X0.8400
 X0.8200
 F80.0000  Z-1.0785
G0  X0.8400
 Z0.1111
G1 F50.0000  X0.8200
 X0.8000
 F80.0000  Z-1.0207
G0  X0.8200
 Z0.1111
G1 F50.0000  X0.8000
 X0.7800
 F80.0000  Z-0.9686
G0  X0.8000
 Z0.1111
G1 F50.0000  X0.7800
 X0.7600
 F80.0000  Z-0.9208
G0  X0.7800
 Z0.1111
G1 F50.0000  X0.7600
 X0.7400
 F80.0000  Z-0.8766
G0  X0.7600
 Z0.1111
G1 F50.0000  X0.7400
 X0.7200
 F80.0000  Z-0.8351
G0  X0.7400
 Z0.1111
G1 F50.0000  X0.7200
 X0.7000
 F80.0000  Z-0.7958
G0  X0.7200
 Z0.1111
G1 F50.0000  X0.7000
 X0.6800
 F80.0000  Z-0.7571
G0  X0.7000
 Z0.1111
G1 F50.0000  X0.6800
 X0.6600
 F80.0000  Z-0.7198
G0  X0.6800
 Z0.1111
G1 F50.0000  X0.6600
 X0.6400
 F80.0000  Z-0.6844
G0  X0.6600
 Z0.1111
G1 F50.0000  X0.6400
 X0.6200
 F80.0000  Z-0.6505
G0  X0.6400
 Z0.1111
G1 F50.0000  X0.6200
 X0.6000
 F80.0000  Z-0.6179
G0  X0.6200
 Z0.1111
G1 F50.0000  X0.6000
 X0.5800
 F80.0000  Z-0.5868
G0  X0.6000
 Z0.1111
G1 F50.0000  X0.5800
 X0.5600
 F80.0000  Z-0.5568
G0  X0.5800
 Z0.1111
G1 F50.0000  X0.5600
 X0.5400
 F80.0000  Z-0.5275
G0  X0.5600
 Z0.1111
G1 F50.0000  X0.5400
 X0.5200
 F80.0000  Z-0.4993
G0  X0.5400
 Z0.1111
G1 F50.0000  X0.5200
 X0.5000
 F80.0000  Z-0.4720
G0  X0.5200
 Z0.1111
G1 F50.0000  X0.5000
 X0.4800
 F80.0000  Z-0.4455
G0  X0.5000
 Z0.1111
G1 F50.0000  X0.4800
 X0.4600
 F80.0000  Z-0.4198
G0  X0.4800
 Z0.1111
G1 F50.0000  X0.4600
 X0.4400
 F80.0000  Z-0.3947
G0  X0.4600
 Z0.1111
G1 F50.0000  X0.4400
 X0.4200
 F80.0000  Z-0.3701
G0  X0.4400
 Z0.1111
G1 F50.0000  X0.4200
 X0.4000
 F80.0000  Z-0.3461
G0  X0.4200
 Z0.1111
G1 F50.0000  X0.4000
 X0.3800
 F80.0000  Z-0.3229
G0  X0.4000
 Z0.1111
G1 F50.0000  X0.3800
 X0.3600
 F80.0000  Z-0.3000
G0  X0.3800
 Z0.1111
G1 F50.0000  X0.3600
 X0.3400
 F80.0000  Z-0.2777
G0  X0.3600
 Z0.1111
G1 F50.0000  X0.3400
 X0.3200
 F80.0000  Z-0.2560
G0  X0.3400
 Z0.1111
G1 F50.0000  X0.3200
 X0.3000
 F80.0000  Z-0.2346
G0  X0.3200
 Z0.1111
G1 F50.0000  X0.3000
 X0.2800
 F80.0000  Z-0.2137
G0  X0.3000
 Z0.1111
G1 F50.0000  X0.2800
 X0.2600
 F80.0000  Z-0.1931
G0  X0.2800
 Z0.1111
G1 F50.0000  X0.2600
 X0.2400
 F80.0000  Z-0.1729
G0  X0.2600
 Z0.1111
G1 F50.0000  X0.2400
 X0.2200
 F80.0000  Z-0.1531
G0  X0.2400
 Z0.1111
G1 F50.0000  X0.2200
 X0.2000
 F80.0000  Z-0.1337
G0  X0.2200
 Z0.1111
G1 F50.0000  X0.2000
 X0.1800
 F80.0000  Z-0.1146
G0  X0.2000
 Z0.1111
G1 F50.0000  X0.1800
 X0.1600
 F80.0000  Z-0.0957
G0  X0.1800
 Z0.1111
G1 F50.0000  X0.1600
 X0.1400
 F80.0000  Z-0.0774
G0  X0.1600
 Z0.1111
G1 F50.0000  X0.1400
 X0.1200
 F80.0000  Z-0.0593
G0  X0.1400
 Z0.1111
G1 F50.0000  X0.1200
 X0.1000
 F80.0000  Z-0.0414
G0  X0.1200
 Z0.1111
G1 F50.0000  X0.1000
 X0.0800
 F80.0000  Z-0.0238
G0  X0.1000
 Z0.1111
G1 F50.0000  X0.0800
 X0.0600
 F80.0000  Z-0.0064
G0  X0.0800
 Z0.1111
G1 F50.0000  X0.0600
 X0.0400
 F80.0000  Z0.0106
G0  X0.0600
 Z0.1111
G1 F50.0000  X0.0400
 X0.0200
 F80.0000  Z0.0274
G0  X0.0400
 Z0.1111
 X0.9000
G1 Z-1.7610
 F50.0000  X0.8800
 F80.0000  Z-2.3750
G0  X0.9000
 Z-1.7610
G1 F50.0000  X0.8800
 F80.0000  Z-1.7940
 F50.0000  X0.8600
 F80.0000  Z-2.3750
G0  X0.8800
 Z-1.7940
G1 F50.0000  X0.8600
 X0.8400
 F80.0000  Z-2.3750
G0  X0.8600
 Z-1.7940
G1 F50.0000  X0.8400
 X0.8200
 F80.0000  Z-2.3750
G0  X0.8400
 Z-1.7940
G1 F50.0000  X0.8200
 X0.8000
 F80.0000  Z-2.3750
G0  X0.8200
 Z-1.7940
G1 F50.0000  X0.8000
 X0.7800
 F80.0000  Z-2.3750
G0  X0.8000
 Z-1.7940
G1 F50.0000  X0.7800
 F80.0000  Z-2.2610
 F50.0000  X0.7600
 F80.0000  Z-2.3750
G0  X0.7800
 Z-2.2610
G1 F50.0000  X0.7600
 F80.0000  Z-2.2940
 F50.0000  X0.7400
 F80.0000  Z-2.3750
G0  X0.7600
 Z-2.2940
G1 F50.0000  X0.7400
 X0.7200
 F80.0000  Z-2.3750
G0  X0.7400
 Z-2.2940
G1 F50.0000  X0.7200
 X0.7000
 F80.0000  Z-2.3750
G0  X0.7200
 Z-2.2940
G1 F50.0000  X0.7000
 X0.6800
 F80.0000  Z-2.3750
G0  X0.7000
 Z-2.2940
G1 F50.0000  X0.6800
 X0.6600
 F80.0000  Z-2.3750
G0  X0.6800
 Z-2.2940
G1 F50.0000  X0.6600
 X0.6400
 F80.0000  Z-2.3750
G0  X0.6600
 Z-2.2940
G1 F50.0000  X0.6400
 X0.6200
 F80.0000  Z-2.3750
G0  X0.6400
 Z-2.2940
G1 F50.0000  X0.6200
 X0.6000
 F80.0000  Z-2.3750
G0  X0.6200
 Z-2.2940
G1 F50.0000  X0.6000
 X0.5800
 F80.0000  Z-2.3750
G0  X0.6000
 Z-2.2940
G1 F50.0000  X0.5800
 X0.5600
 F80.0000  Z-2.3750
G0  X0.5800
 Z-2.2940
G1 F50.0000  X0.5600
 X0.5400
 F80.0000  Z-2.3750
G0  X0.5600
 Z-2.2940
G1 F50.0000  X0.5400
 X0.5200
 F80.0000  Z-2.3750
G0  X0.5400
 Z-2.2940
G1 F50.0000  X0.5200
 X0.5000
 F80.0000  Z-2.3750
G0  X0.5200
 Z-2.2940
G1 F50.0000  X0.5000
 X0.4800
 F80.0000  Z-2.3750
G0  X0.5000
 Z-2.2940
G1 F50.0000  X0.4800
 X0.4600
 F80.0000  Z-2.3750
G0  X0.4800
 Z-2.2940
G1 F50.0000  X0.4600
 X0.4400
 F80.0000  Z-2.3750
G0  X0.4600
 Z-2.2940
G0X1.0420
G0Z0.1111
 (--------------ToolPath 2 of 2 )
 (-------------- Fine Path -----------------)
T0000
S3000 F80.00 M3
G0 X0.5100
G0 Z0.0011
G1 Z0.0011 X0.0371
  Z-0.0365 X0.0587
  Z-0.0887 X0.0876
  Z-0.1415 X0.1153
  Z-0.2038 X0.1464
  Z-0.2579 X0.1719
  Z-0.3215 X0.2003
  Z-0.3766 X0.2235
  Z-0.4322 X0.2456
  Z-0.4976 X0.2700
  Z-0.5541 X0.2897
  Z-0.6111 X0.3083
  Z-0.6780 X0.3285
  Z-0.7357 X0.3447
  Z-0.7938 X0.3596
  Z-0.8619 X0.3757
  Z-0.9206 X0.3882
  Z-0.9893 X0.4013
  Z-1.0486 X0.4113
  Z-1.1080 X0.4200
  Z-1.1676 X0.4276
  Z-1.2373 X0.4349
  Z-1.2972 X0.4400
  Z-1.3572 X0.4438
  Z-1.4273 X0.4467
  Z-1.4575 X0.4475
  Z-1.4674 X0.4476
  Z-1.4975 X0.4484
  Z-1.7490 X0.4485
  Z-1.7524 X0.4475
  Z-1.7936 X0.4475
  Z-1.8036 X0.3860
  Z-2.2459 X0.3860
  Z-2.2518 X0.3850
  Z-2.2995 X0.3850
  Z-2.3095 X0.2110
  Z-2.3709 X0.2110
  Z-2.3750 X0.2103
G0 X0.4585
   Z0.0011
G1 Z0.0011 X0.0256
  Z-0.0414 X0.0500
  Z-0.0934 X0.0788
  Z-0.1461 X0.1064
  Z-0.2082 X0.1374
  Z-0.2620 X0.1628
  Z-0.3255 X0.1911
  Z-0.3804 X0.2142
  Z-0.4358 X0.2363
  Z-0.5010 X0.2606
  Z-0.5573 X0.2802
  Z-0.6141 X0.2988
  Z-0.6808 X0.3189
  Z-0.7383 X0.3351
  Z-0.7962 X0.3499
  Z-0.8641 X0.3659
  Z-0.9225 X0.3784
  Z-0.9911 X0.3914
  Z-1.0501 X0.4014
  Z-1.1093 X0.4101
  Z-1.1687 X0.4177
  Z-1.2382 X0.4250
  Z-1.2979 X0.4300
  Z-1.3578 X0.4338
  Z-1.4276 X0.4367
  Z-1.4576 X0.4375
  Z-1.4676 X0.4376
  Z-1.4976 X0.4384
  Z-1.7476 X0.4385
  Z-1.7510 X0.4375
  Z-1.7851 X0.4375
  Z-1.7951 X0.3760
  Z-2.2451 X0.3760
  Z-2.2510 X0.3750
  Z-2.2901 X0.3750
  Z-2.3001 X0.2010
  Z-2.3701 X0.2010
  Z-2.3750 X0.2002
G0 X0.5100
(--------------End of Finish path-----------)
 M5M30
(-------  End of File -------)
Post by: Overloaded on January 31, 2012, 03:43:26 PM
Hi Jim, I'm certain RICH will get back to ya.
In the mean time, all looks good here with your DXF, perfect.
I am also in DIA mode, Mach and LT.
Everything comes out fine here.
Russ
Post by: Overloaded on January 31, 2012, 04:05:20 PM
also, I get a different output from LT, mine is on the right.
Wondering if you are running thae latest version.
Post by: jchronister on January 31, 2012, 04:45:32 PM
Thanks for the reply overload- I downloaded it 2 weeks ago. Not using Mach- Just lazyturn. Then taking it to our old dos version of Microturn 2.12. Tried on several computers- XP and Windows 7. No difference.
Post by: RICH on January 31, 2012, 04:57:54 PM
Using the file you posted I had no problem generating code from Lazyturn in diameter mode.
See Pic DIAMETER MODE_HCIR1
Then I ran the gcode file in MacH3 Turn. ( had to edit a few lines because of more than one line number on the same line  )
See Pic DIAMETER MODE_HCIR2
Then I backplotted the gcode and copied your drawing to compare the code to the pathing form LazyTurn.
See pic ACAD DXF OVERLAY TO CODE
Missunderstanding .....draw your full size full size and just save as a version 12 DXF.
( What i meant was ,some follks for whatever reason will draw half size, then use the diameter  / radius option to enlarge it,
and then who knows what mode they are in in Mach3 Turn...you just don't do goofy stuff like that)
I have never seen that and need to fool around to see what you did to accomplish it!  ;)
See pic DOUBLE ACAD DXF OVERLAY TO CODE
The problem is that Denford doesn't support the older machines  ???
I don't know what you mean .....
Post by: jchronister on January 31, 2012, 06:32:47 PM
Overload- Where did you get your release? You're showing a definite different release. My code never has the line stating diameter mode and being an alpha may be the problem (I hope). I downloaded it from here: http://www.machsupport.com/downloads.php
LazyCam 3.01. Just tried to download it again and it's definiely alpha, not final. Here's my help splash screen attached.
There really aren't a whole lot of setting I could have messed up ( a real positive for high school students), but I'm sure I could have done something. I saw 2 other postings in these forums where this problem was mentioned, but didn't really see any replies to them. I'm wondering if it's an alpha thing.
Post by: jchronister on January 31, 2012, 06:39:55 PM
Rich,
Thanks for testing my file. Everything looks as yours does on my screen. The bars show diameter mode and when I simulate the paths, they look great. Tool runs as it should. When I post the code, what you see is what it gives me. I need to change the first few tool lines on each path so it runs on my lathe and it makes great rough passes, but I need to hit the escape key for the finish pass or it does what your cad overlay shows... a chunk of wood flying out of the chuck :)
Post by: Overloaded on January 31, 2012, 10:38:51 PM
I think this is the last one I used ... not sure though, try it.
Russ
Post by: Overloaded on January 31, 2012, 10:40:38 PM
http://www.machsupport.com/forum/index.php/topic,5767.msg95122.html#msg95122
From the manual, version to download.
Post by: jchronister on February 01, 2012, 04:43:08 AM
Got the one from your last post and it generates the code perfectly! Didn't change a thing and it worked so it must be that alpha version. I'll try running it on the lathe when I get to school this morning and post my results.
Looks promising- Thanks!
Post by: Overloaded on February 01, 2012, 06:29:58 AM
That's great Jim !
Hope all is well now, will check back later today to see.
Might be the wrong version with LC on that downloads page ? ? RICH, can you verify ? ?
Russ
Post by: jchronister on February 01, 2012, 01:16:05 PM
Just a last shout out- I want to thank you gentlemen for all the help. It was definitely the alpha version issue. Ran 5 different nosecone shapes and a complex chess pawn without a single error today. Parts turn so nice on a dowel rod that they don't even need sanding! ( i will give some of that credit to my nicely ground and honed tool :-)
All I have needed to do is delete a few lines at the start of each path dealing with tools and insert a few lines of my own. Pretty simple.
Now I'm looking at Mach3 as a possible upgrade to my old DOS microturn 2.12 driver software.
Thanks again!
Jim
Post by: Overloaded on February 01, 2012, 05:20:11 PM
That's great news Jim !
Always anxious to see pics of LT produced turnings, yours sound really nice.
Please post some if you can.
Also, you can enter whatever you like in the Code Prolog box before generating the code, might save some editing.
Russ
Post by: RICH on February 01, 2012, 06:24:13 PM
Russ,
I'll see what can be done so a user can download what is required for a stand alone installation of LazyTurn.
I am not sure what additional files are required and after downloading the latest LC  & LT version I had to copy  a dll file into the directory to get LT to work.
Should be no problem if one installs Mach3.
Post by: RICH on December 31, 2014, 06:18:31 AM
half size, then use the FIFA 15 Coins diameter
Not familar with FIFA....????? ???
