Mach Discussion => General Mach Discussion => Topic started by: plasmacutting on January 21, 2012, 02:06:08 PM
Title: axis are stopping during cutting process?
Post by: plasmacutting on January 21, 2012, 02:06:08 PM
Why my plasmatable axis are stopping for a moment during the cutting process when M15 (THC off) is read from G-code? If M15 is erased from G-code, cutting is continuous.
Title: Re: axis are stopping during cutting process?
Post by: Hood on January 21, 2012, 02:07:48 PM
What is in the M15 macro?
Post by: plasmacutting on January 21, 2012, 02:23:37 PM
I have no macro for M15
Post by: Hood on January 21, 2012, 02:50:17 PM
Then why do you have M15 in your code?
Post by: plasmacutting on January 23, 2012, 11:47:51 AM
Whoops! M15 macro is: "Deactivatesignal(output2)"
Post by: Hood on January 23, 2012, 01:03:54 PM
What do you use OutPut2 for?
Post by: plasmacutting on January 24, 2012, 02:53:47 AM
It swiches off automatic arc height control before leadout or in case it is better to cut in manual THC mode.
Post by: Hood on January 24, 2012, 03:01:59 AM
If the pause is only during the line with the macro then it is because Mach is reading the macro and acting on it so there will be a momentary pause, not much you can do about that.
You could try putting it on the same line as code but whether that would help I dont know, likely not.
Post by: plasmacutting on January 24, 2012, 03:21:33 AM
I will try, thanks a lot!
Post by: Hood on January 24, 2012, 04:24:02 AM
It may be possible for you to instead utilise the M110/M10 commands instead.  It may not be working in the present download but should be soon in the development version.
Post by: plasmacutting on January 24, 2012, 07:38:01 AM
Thanks! This would be another topic but I would need some with XY offsets again. I have used G54 and G55 for torch and Scribe. Now Homing swiches are installed and therefore this offseting is not working anymore. What would be the procedure for setting offset parameters for G52?
Post by: Hood on January 24, 2012, 09:02:34 AM
Simply G52X*Y*  where * are the values you wish to offset the axis. G52 X0Y0 will set them back.
Post by: plasmacutting on January 26, 2012, 02:43:57 AM
It was easier than I expected - works fine, thanks a lot!
Post by: plasmacutting on May 15, 2012, 08:35:02 AM
I have now updated Mach. How can I use M110/M10 commands to deactivate output 2 (THC off) instead of M15, to prevent axis stopping during the process?
Thank you in advance!
Post by: stirling on May 15, 2012, 09:35:01 AM
So you're getting dive at kerf crossing and/or slow down at leadout.
You should really use anti-dive but if you prefer to switch off THC then you can't do it with ANY macro without Mach stopping. It's not so much that a macro takes time to do what it does, it's because Mach's CV planner doesn't blend movement accross a macro call and therefore you get an exact stop between the two moves.
Do a search for the E1P0/E1P1 command family which were created for laser users but may help you.
Ian
