Mach Discussion => General Mach Discussion => Topic started by: Dotty on January 18, 2012, 06:35:34 AM
Hi
Firstly, I am completely new to CNC. I have aquired a CNC router that is controlled by mach 3, I have spent a few weeks reading and setting up the machine and have got to the point were I can home the x, y and z axis. The only thing I cant get to work is the spindle. Mach 3 starts ( i can even run code) and all the axis work but the spindle does not come on. I have looked in the diagnistics screen and if I toggle the spindle I get a flashing light that i understand means the soindle should be working. Has anyone got any ideas of the mistake i have obviously made...
Thank you
Ashley
Make sure you have the correct correct information in Config - Ports N Pins - Motor Output - Spindle.
The light on the diagnostics screen will light up, but if you do not tell it where to send the signal
you will not have any movement.
Hope this helps!!
olf20 / Bob
Thanks for the reply Bob.
Had a look throgh the lit that came with the machine and it tells me to configure the spindle in Motor Outpits tab to: step pin: 16 dir pin 17 step port 1 and dir port 1, this is all done ok. Now I am getting a new message "PWM Bumped to Minimum Setting" - if i change the PWM setting i can get rid of this message but still no spindle responce at all. When I press the spindle toggle button I do hear the relay click buts thats it.
Any help would be much appriciated.
What type of spindle drive do you have??
Brand ?
Type Step / Direction, PWM
Any spec will help!1
Are the signals from Mach3 getting to the
spindle control board?
olf20 / Bob
Hi Bob
I have done some investigating last night and the results are as follows:
The spindle is not branded, it is a water cooled (seperate pump so the cooling works) GDZ-80-2.2 dia80*210 220v - 2.2kw 8A 400hz 2400rpm
I checked the pins at the end of the parellel cable and I have a constant 4.9v at pins 1 - 9 - 14 - 16 -17
Settings in Mach3: Motor outputs are set to: step pin 16 Dirpin 17
Output signals: enable1: port 1 pin14
enable2: port1 pin1
output1: port1 pin16
I have power into the spindle control panel but no power at the output leads to the spindle.
pwm base freq 1
minPWM 0
this was set to 10 and 2 but this trips out the system .
If you need any further info please let me know.
Can you post your xml file. Maybe we can see something there.
Also can you run the spindle manually??
That would ensure that everything on that end is working.
olf20 / Bob
Hi Bob
Just had a local electrical rewinds co out to see the control box, they say it all seems to be operating fine. They found a digital counter on the main spindle control board and assumed that this would need to change from 000 to 001 or something to start the spindle - therefore , they came to the conclusion that it was waiting for a input signal to start the spindle. They checked the spindle and all ok.
Sorry i am very new to CNC - can i ask "what xml file and were do i find it?
Thanks Ashley
Found this file ?
[mod: attachment deleted]
From the looks of your xml file you should have pin 16 connected to your
input to your spindle drive.
What other devices are you controlling with your outputs?
Also on page 5-17 (may vary some depending on version of manual)
item 5.5.6.2 defines the steps to setup the spindle PWM outputs.
On the MDI screen if you type in M3 S1000 does anything happen?
olf20 / Bob
Dotty
Have sent you a PM.
Hi Bob
Not sure what I have done but the spindle now works with the toggle button. I have run a very short gcode and for the first time the spindle ran up. Thank you. The first time i entered M3 s1000 in the MDI screen it worked, since then I have tried a number of times and i just get the error message saying a limit switch has been triggered - no limit switches have been hit.
In answer to your question, I only have three stepper motors and the spindle - no other devices.
Dotty - You are using a pirate licence - You will get no further help here. If you feel this is in error contact Mach licencing support.
