Mach Discussion => General Mach Discussion => Topic started by: milehigh51 on January 15, 2012, 10:53:43 PM
Title: Upgraded to new hardware, Turn won,t run
Post by: milehigh51 on January 15, 2012, 10:53:43 PM
Hi All
I upgraded to new hardware MB AMD 145 Single core processor.
When I load Mach3 Turn it locks up the CPU. Mach3 mill loads fine.
I have tried several versions of mach with the same results
Thank You
Roy
Title: Re: Upgraded to new hardware, Turn won,t run
Post by: Hood on January 16, 2012, 02:05:32 AM
Do you have any brains or a macropump or any plugins in Turn that you dont in mill? Do you have a high kernel chosen in Turn?
If you attach your xml I will have a look and see if I can spot any issues.
Post by: milehigh51 on January 17, 2012, 08:15:14 PM
Hi Hood
Thanks for the reply.  I did find the problem.  In the bios disabled the following
secure virtual machine
power now
acpi srat table
C1E
This mother board is a Biostar  AMD 3 chip set.
I hope this may help someone else.
Roy
