Mach Discussion => General Mach Discussion => Topic started by: Hood on December 27, 2006, 10:16:48 AM
I am going to be starting on my Lathe retro when I get the parts I need and I want to make up a screenset similar to the one I have for my mill. I have never used a CNC lathe before and looking at the lathe screensets available they are quite a bit different from the mill layout, so I am looking for opinions on what layouts you guys think is best. Is there a reason for the lathe screenset being so different from the mill? What buttons, DROs etc do you think should be on the main screen? Do you always have seperate reference (home) buttons for a lathe or can they be like the reference button in mill (does all axis one after the other)?
Any suggestions would be appreciated.
I like the Mach Silverblue screen myself, one of the series that Mr Beano and company made about 8 months ago. No bugs in it that I have found, very pleasant to use. I would like the cycle start button to be larger as I use a touchscreen, but that's about it. Now if Mach just had a DXF roughing cycle, or some kind of profile roughing cycle like the mill software has, it would have everything! I can't get the one touch reference button to work for some reason, I just do the two referencing processes seperately. Hard for me to compare any of Mach's mill features as I have never used it, only the lathe setup.
A picture is worth a thousand words. ;D
Thanks guys.
Been looking at the screens and I can kind of see the way they work might be best, will play with the lathe a while and then I will probably make a screen to suit the way I work.
