Mach Discussion => General Mach Discussion => Topic started by: comet on January 01, 2012, 08:06:31 AM
Hi,I want to have 2 mpg'd on my 3 axis mill,mpg1 will switch between Y & Z axis using 186 and 187 oems, but I want mpg to be on x only I dont really want to use 281 toggle axis for that.Any Idea?
regards
Tony
Use dedicated pins for the X mpg?
not really with you there Rich? dedicated pins? Im using a pci pp card to operate the mpg set up
how do I dedicate the pins?
I use two MPG's and in Config>Ports & Pins> Encoder/MPG's....MPG#1 & #2 are enabled, use the same port but use 4 different
pin assignments for the A & B Pin#.
