General CNC Chat => Show"N"Tell ( What you have made with your CNC machine.) => Topic started by: budman68 on December 20, 2011, 06:35:51 PM
Title: Sometimes it's the quick and easy ones......
Post by: budman68 on December 20, 2011, 06:35:51 PM
Sometimes it's the quick and easy ones......that are the most fun  :)
Took a moment today to diamond drag engrave this "W" in our clocks' pendulum for a nice little extra touch.
Happy Holidays to all!
Title: Re: Sometimes it's the quick and easy ones......
Post by: Chaoticone on December 20, 2011, 08:40:12 PM
Looks good Dave!  Happy Holidays to you too!
Post by: Tweakie.CNC on December 21, 2011, 03:39:27 AM
Nice touch Dave.  ;)
Presumably spring loaded but what type of tool did you use please ??
I echo your comments Happy Holidays to all.
Post by: budman68 on December 21, 2011, 03:49:19 AM
Thanks fellas, and it is actually a tapping guide that I turned into a spring loaded engraver.
I think I actually posted info about it years ago, but will look again for the pics when I get home from work.
Post by: budman68 on December 21, 2011, 10:32:57 AM
Ok, Tweaks, here you go. This is from a post I just did on the Vectric forum as well:
I use a tap guide (for threading) and quite honestly, the hardened pointed/ground end works great for this as well, as I used that at first with other projects I've done. I wanted to set it up for a diamond tip though, so I designed an adapter to fit inside with a small set screw to hold what are called "phonopoint" diamonds (cheap!), which are really used for dressing precision grinding wheels on a surface grinder (what I do for my "day" job). It works fantastic and they make the guides with such a nice slip fit, and hardened materials, so it's a quality unit. I've done over 130 drag engravings with it and it's still a perfect slip fit.
(I see Enco doesn't allow hotlinking anymore so here are the part numbers:)
website: http://www.use-enco.com
Phono/Single point Diamond: 388-8860
Tapping Guide: 325-5179
Rendering of the diamond point adapter shown below.
Hope that helps-
Post by: Tweakie.CNC on December 21, 2011, 10:57:30 AM
Thanks for the information Dave.
(I can feel a little turning job coming on  ;) )
Post by: Sam on December 21, 2011, 03:47:40 PM
Looks great, Dave!
Post by: budman68 on December 21, 2011, 04:17:06 PM
Hey Sam, you must be busy, you haven't been around much, my friend. How goes it?
Post by: Sam on December 22, 2011, 01:42:32 AM
Going fine I recon Dave. Doing better than I deserve, I guess. I've not really had time to do any personal projects to share with the masses lately. I'm around here every day though, I just lurk in the shadows.
Post by: budman68 on December 22, 2011, 09:01:13 AM
Good to know Sam,  ;)
Post by: bwprice100 on December 29, 2011, 07:23:39 AM
Hi Dave
Looks very nice.
Typically what sort of depth have you achieved and was it done in a single pass?
Thanks Brian
Post by: budman68 on December 30, 2011, 06:48:19 AM
Hi Brian,
Thank you for the kind words. While I haven't actually checked with an indicator, it seems I get about .010" depth with 2 passes in 6061 aluminum and probably about .005-.006" in engravers brass. The pendulum was a bit more as it's very thin, and easily manipulated as it's hollow, not solid. 2 passes are better as the first pass sometimes gives "hair-like" burrs that seem to be eliminated on the second dry run pass.
