Mach Discussion => General Mach Discussion => Topic started by: Saumur on December 12, 2011, 10:47:48 AM
Hey guys,
is it normal that if I install Mach3 directly from the site it works correctly; when I transfer the installer using a USB memory the input of the computer to the drives does not work, and therefore the drives doesn't turn on.
Why is that?
I don't believe I've ever heard of that one, but I'm sure if anyone has, they'll speak up. Keep watching-
Saumur,
I install from USB flash drives since my three machine computers do not connect to the WEB. No problems. Are you running the driver test after each new installation?
John Champlain
www.picengrave.com
