Mach Discussion => General Mach Discussion => Topic started by: BR549 on November 28, 2011, 10:13:45 PM
Hiya Andrew would it be possible to fix the G28.1 gcode so that it would work with a G68 in plasma work??? We use the G28.1 to home the Z axis to the top of materail BUT it will not run as long as the G68 is rotated.
I understand that you would not want to home while the X/Y were rotated but allowing Z to run should not effect that .
I would be a big help to the plasma world running Mach3.
Thanks (;-) TP
