G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: LarryL on November 17, 2011, 12:09:32 PM
Title: Is it possible to call an external gcode file from within a gcode file?
Post by: LarryL on November 17, 2011, 12:09:32 PM
I am trying learn if it is possible to call an external Gcode file from within a Gcode file that is running.  What I am trying to do is be able to make a macro from a pattern repeating file that will call up the external pattern and repeat it the number of times entered into Gcode.
Larry
Title: Re: Is it possible to call an external gcode file from within a gcode file?
Post by: BR549 on November 17, 2011, 07:15:04 PM
Yes it is called a SUB. You store the SUB in the SUB directory and call it with the M98 sub call in the Gcode program.
You can find more info in the Mach3 manual.
Post by: LarryL on November 20, 2011, 07:26:19 AM
Great, Thanks
Larry
