Mach Discussion => General Mach Discussion => Topic started by: bigbloke on November 16, 2011, 04:26:17 PM
Hi
I have a Smoothstepper with C32BOB.
I did get it all working a year back on the bench but since then have been distracted by other projects. I have now built it all into a nice cabinet and wired up for installation into the machine.
Unfortunately the PC had to be replaced in the intervening time and as a result, I lost the working XML and settings.
On the new PC, I have downloaded and installed mach, the current Smoothstepper driver and plugin and the latest C32 R4 XML, I have re created the input and output port settings in Mach from the scrrenshots in the documentation I did last year. Both PCs run 64bit windows 7.
The PC starts mach up nicely, offers a choice of profiles, offers a choice of interfaces so I take the C32 XML option and the Smoothstepper interface, the 3 working happily lights come up on the smoothstepper, so far so good.
Mach 3 comes up with a re-configuration e-stop, which I clear. It then comes up with an external e-stop which I clear, it then shows an emergency which I clear, this basically goes on forever. It seems to take a couple of seconds to realise that it has a problem after clearing then it goes right back to an emergency.
I have disconnected everything but the smoothstepper and the power for the C32 to simplify the setup, this didnt seem to change the behaviour of the setup.
Have tried setting E stop to active low but no joy so set it back to normal.
Does this sound familiar to anybody. Probably a really simple error, I just cant see it.
Any help / thoughts would be much appreciated.
Paul
Do you have limits enabled? If so they could be the issue if you have the active state wrong.
Hi Hood
Just checked, No limits are set, auto zero is set on all axes.
Any other thoughts ?
Paul
attach your xml and I will have a look.
Here it is, I hope
Thanks for looking
Paul
So just to clarify you do have limit swotches on the machine but when you look on diagnostics there are no LEDs for them?
Also do you have an E-Stop switch? If yes is it a Normally Closed switch and connected to pin 10?
Hi Hood
Yes, I do have limit switches on the machine. They are not actually connected up yet.
To exclude any external wiring faults as far as possible, I have disconnected all inputs and outputs apart from the E stop button.
The e stop is on port 1 pin 10 and is normally closed.
I can get comms with the smoothstepper going just fine but as soon as I put power on the C32, the emergency light comes on in Mach. If I monitor the LEDs then nothing is lighting up except the Emergency LED.
I have now even tried turning all inputs and outputs off in Mach ports and pins to see whether that makes a difference, it doesnt.
Baffled
Paul
Strange that its fine unless you power the OB, try changing the active state of the e-stop and see what happens.
Hi Hood
I've now disconnected absolutely everything but the gnd and 5 V, as soon as the power is applied, the board sets emergency and wont clear.
I've logged a call with CNC4PC, I'm starting to wonder if I've damaged something.
Paul
Seems strange its fine until you power the bob as I would expect an E-Stop without the BOB powered as its looking for a normally closed signal and I would imagine without the BOB being powered the SS would see it open.
Hi Just an update.
Embarassingly, it seems to have been a wiring or switch fault on the e-stop. Arturo suggested I just use a short wire link on the board estop terminals to eliminate any potential wiring issues. The problem cleared immediately.
Strange though, I thought I had done the same a couple of days ago before posting on here.
Still nothing moving but at least the board seems to be responding. I can hopefully work through the rest over the next few days.
Thanks very much for the help & advice.
Paul
Good news and dont be embarrassed these things happen to everyone :)
