Mach Discussion => VB and the development of wizards => Topic started by: rrc1962 on October 23, 2011, 11:26:56 PM
Is there a way to open a file open dialog in a VB script. I'm not trying to load G-Code, so button 216 won't work. Just need to select a file, open it and do some things with it in VB. Typing the full path in a DRO is a drag.
What type file are you talking about ? Gcode , txt file, data file??????
From CB you can open a file directly and read and write to it. OR you can open a Gcode file with notepad and edit it.
I need to open a text file and parse it. I can open the file and manipulate it fine, but in order to open it I have to type the file name in a DRO. I want to display a file open dialog instead.
I use something like this to open files by file name.
Fname = InputBox("What is the New File Name","Grank Grind FILENAME", DFN)
It gives you a popup box to answer the question
THe use the variable "Fname" to open a new file
Set objDialog = CreateObject("UserAccounts.CommonDialog")
objDialog.Filter = "Text Documents|*.txt|All Files|*.*"
objDialog.FilterIndex = 1 '*.txt is default
objDialog.InitialDir = "."
intResult = objDialog.ShowOpen
If intResult = 0 Then
'user hit cancel
Else
'filename is in objDialog.FileName
End If
Season to taste but beware - there be dragons - it'll work in XP but not much else.
Ian
Cool. Thanks very much. I had seen this done in VB script but didn't see it anywhere in the Cypress Enable docs. Didn't think it would work in CE.
That's sort of the way I was doing it, except I just used a DRO. Typing the file name just started getting old.
This is an old thread, but it seems like the best place to post some new info. Our machine controller is running XP, but I just upgraded to a new Windows 7 machine for development. Under XP, I've been using the following incantation to create a file dialog:
Set ObjFSO = CreateObject("UserAccounts.CommonDialog")
ObjFSO.Filter = "Text Documents|*.txt"
ObjFSO.FilterIndex = 1
ObjFSO.InitialDir = "c:\PCNC3\Nagahara\MeasureKeys"
InitFSO = ObjFSO.ShowOpen
If InitFSO = False Then
Exit Sub
End If
PathName = ObjFSO.FileName
Apparently there are security issues with this approach and Microsoft has done away with it in Vista and Win7. Searching the web, I found several different approaches (http://stackoverflow.com/questions/4386124/how-can-i-use-the-common-save-as-dialog-from-vbscript) that people have come up with to present a file dialog. IMO the cleanest and most portable is here (http://www.jsware.net/jsware/scripts.php5#jsshl). After installing this new dll on XP and Win7, the following code works under both operating systems to display a file dialog:
Set jsS = CreateObject("jsShell.Ops")
sFile = jsS.OpenDlg("Select file.", "txt", ""c:\PCNC3\Nagahara\MeasureKeys")
David
