Mach Discussion => General Mach Discussion => Topic started by: engineeron on October 23, 2011, 12:45:30 PM
Title: drives will not reverse
Post by: engineeron on October 23, 2011, 12:45:30 PM
I can jog in one direction only.  I replaced the BOB (DB25) recently and i also replaced my computer because the mother board was fried..  The Y  would reverse for a while   but when I made some changes it will work only one way now.  All seems ok in the program but may not be.  Help  Help
Title: Re: drives will not reverse
Post by: Hood on October 23, 2011, 02:00:59 PM
Either bad wiring  for the Dir pins, bad bob  or you do not have the correct pins or ports assigned for the Dir pins.
Post by: engineeron on October 23, 2011, 05:02:27 PM
I have all axis working in both directions Now ..except the X  axis.     I have checked and rechecked ports and pins setup  and  all checked to specs.  I was wondering if one wire is wrong on the bob. It maybe something simple.  Help
Post by: Hood on October 24, 2011, 02:05:31 AM
If you have a spare output on the BOB rewire the X Dir to it and re-assign in Ports and Pins, Motor Outputs to that pin and see if it helps.
Post by: engineeron on October 24, 2011, 02:42:27 PM
Thanks for the help... It worked.  I changed the wires on BOB for the X dr.  from  2 and 3   to  8 and 9 :)
Post by: Hood on October 24, 2011, 03:30:46 PM
:) good you got it :)
