Mach Discussion => General Mach Discussion => Topic started by: simpson36 on October 21, 2011, 04:49:03 PM
Title: Mach BUG in xx.50 skip line after sub is back.
Post by: simpson36 on October 21, 2011, 04:49:03 PM
Old bug has returned.
Also check the thread on Cutter comp for description of another bug in that function.
Title: Re: Mach BUG in xx.50 skip line after sub is back.
Post by: HimyKabibble on October 21, 2011, 05:22:33 PM
And one other oddity I just found:  My pendant uses a macropump "driver".  I use the pendant to send CycleStart when running programs.  But, with v50, everywhere I need to do a CycleStart, I must do it TWICE with v50.  The first one seems to execute one line of G-code, then stop again.  The second one starts the program running normally.  Odd thing is, on-screen buttons work fine, it's only the CycleStart function on my pendant that no longer works.
