Mach Discussion => Feature Requests => Topic started by: Tarak on December 19, 2006, 12:55:54 PM
Any chance of being able to use IF, THEN, GOTO, DOWHILE etc etc?
Does anyone else have any uses for these or is it just me??
That is a major job and will not happen... There is VB and I can help you with that ;)
Hi Brian,
Thanks for the reply, I'm really keen to be able to use parametric programming. Where should I start to be able to use it?
The main one I would use is as follows.
#100=4 (No. of Repetitions)
N10
IF[#100 EQ 0] GOTO10
PROGRAM
#100=[#100-1]
GOTO10
N20
And also DOWHILE as per below.
#100=4 (NO OF REPEPTITIONS)
WHILE [#100 GT 0] DO1
G01 X100. F1000
#100=[#100-1]
END1
Thanks.
Darc
You can do that this way :-
O1000
(MAIN PROGRAM)
G00 X0 Y0 Z0
M98 P1001 L4 (JUMP TO SUB PROG 4 TIMES)
M30
O1001
(SUB PROGRAM)
G01 X100. F1000.
.... Etc
M99
Graham.
I was hoping to use the IF or the DOWHILE function, so I can have calculations inside the program, so it's smart enough to work out various things and jump backwards and forwards when neccesary with the GOTO command.
Use the Force! (VB)
It is not as bad as you think... For example
Code"X" & Xpos & " Y" & Ypos
This will output a line of Gcode with whatever you have Xpos and Ypos set to
Sorry for the slow response, I've been away on holidays.
BTW, it would be used for a cut off machine.
I was thinking of having a program much like below, is it possible to have it attached to a button?
e.g when I push the button with 20mm on it, it will run the below program?
e.g when I push the button with 16mm on it, it will run the below program but with 16.0 in the variable #1?
;Y0.0 is always the centerline of the bar of steel
#1=20.0 ;Variable Bar Ø
#2=[#1/2]
G90 G55 G21
G00 Y[#2+1.0] ;Rapid into 1.0 away from job
G01 Y[#2-[#2*2]-1.0] F300 ;Cuts in to -11.0 (½Ø + 1.0 further)
G00 Y300.0 ;Pulls away from the job
M30
If the answer is no, please feel free to explain how I would go about using VB scripts instead.
Thanks.
Darc
Darc,
You can do this, its simple.
I can think of two ways.
1. If you are always using the same diameters (for example 10 different diameters), do a screen (or wizard) with 10 buttons, each with the VB code for each diameter, so you will have a button for 20mm, a button for 16mm, and so on and so forth. You will have to use the sintax required to run a gcode in VB.
2. If you have a large number of diameters and it is prohibitive to have a button for each, make a screen (or wizard) , with a DRO in which you can input the diameter of the bar you want to cut. then Just have a button that reads that DRO and inserts it in the #1 variable you proposed.
Hope that gets you started.
Regards
Fernando
Thanks fer mayrl, I just made up a quick screen, I placed multiple buttons on it, with different sizes on each of them.
Could you please give me an example of the syntax I would need to run an G code program from VB?
From the top of my head I beleive its like the following:
for a 20mm bar following the program you posted
CODE "G90 G55 G21"
CODE "G00 Y11" ;Rapid into 1.0 away from job
CODE "G01 Y-11 F300" ;Cuts in to -11.0 (½Ø + 1.0 further)
CODE "G00 Y300.0" ;Pulls away from the job
CODE "M30"
basically the syntax is the following:
CODE "whatever Gcode you want"
You can add variables to this syntax like this
#1=GetOEMDRO( DRO number) ;whatever DRO you put in the screen, lets say you put a 10 in that DRO
FEED=GetOEMDRO( DRO number); whatever DRO you pout on screen for inputing the feed rate, let say you put a 300 in that DRO
CODE "G01 y" & #1 "F" & FEED
this woudl simulate the following line
G01 y10 F300
Fernando
Thanks Fernando, I think I've got the idea now.
Just one thing, when I select "Edit Button Script", then select the button, I entered the code saved it as 03mm.ms1.
How do I tell the button to keep using that script, everytime I open the script for that button it is blank???
Not sure what I'm doing wrong.
Thanks again.
Can you do the script in Screen Designer 4 and save your screen set?
Darc,
just save the code, dont save it as something else, that should work
Regards
Fernando
Thanks Fernando you are the MAN, it works a treat......
Not a problem, thats what we are here for.
Just glad I can give smething back to our comunity
Fernando
Just out of curiosity, is it possible to have the toolpath preview window display the program that is run after you depress the button.
Also is it possible to have a single sblock button, I tried one and it didn't work (single step).
Thanks.
in order to be able to have a toopath window, and be able to single step, you will need to add a button to post the code directyl on the mach3 window, look at other wizards that have the post code button to learn how to do that. I dont know for sure how to do that, but looking at ready made wizards will help you for sure.
Regards
Fernando
Hi guys,
I am new to this particular forum, being the developer of the CNC Quilting Machine. I am looking for some code that will assist me in determining the number of repetitions that I can sew into a given area. Given, only two axis are used, x=length and y=width. where y will be constant at approx. 6-8 inches, x can be as short as 10 inches or as long as 70 inches. What I would like to do is be able to input the size of the pattern, i.e., 8"x7" and return the number of repititions that will fit in the x length. Simple division, but I am not a whiz with math. Help!!!!
Larry
