Mach Discussion => General Mach Discussion => Topic started by: Jackal on October 18, 2011, 08:14:01 PM
Title: Mach won't let me tune motors. Dialog page won't open??
Post by: Jackal on October 18, 2011, 08:14:01 PM
During my  mission to get Mach to recognize the #2 parallel port, Windows XP went crazy. >:D
It kept saying "new hardware device found" every 10 seconds, and doing other wild stuff.
My .xml file was saved/backed-up, so I just reformatted my computer.
Now,I have loaded Mach 3 and  the .xml with all of my tuning.
For some strange reason when I go into the "Config" tab, it shows the motor tuning, but the motor tuning page won't open.
It is something I hit by mistake. :-[
Thanks a lot,
JAckal
Title: Re: Mach won't let me tune motors. Dialog page won't open??
Post by: Hood on October 19, 2011, 02:14:25 AM
Do you have the driver installed?
Post by: Jackal on October 19, 2011, 07:24:15 AM
Hood,
I didn't go through the basic steps for a first time installation. It was re-booted like you are supposed to do.
Would it still jog the servos if the driver wasn't installed?
My thinking was that the driver test, and other stuff was to see if the computer was compatible with Mach. :-[
Today, I'll remove & reinstall the driver.
JAckal
Post by: Hood on October 19, 2011, 10:19:03 AM
No if the axis jog the driver is installed correctly. Hopefully the reinstall will fix you up.
Post by: Jackal on October 19, 2011, 03:42:31 PM
Everything is set back up. Windows XP, Mach 3  with my last good working .XML file, etc.
The motors jog ok,and  the motor tuning page opened up, too.
Now it wont, after I added the CNC4pc brains, and the 2nd parallel port.
It seems to me, like it is the port drivers, or the CNC4pc brains.
Stay tuned, after I remove  those extras and check it.
JAckal ;)
Post by: Jackal on October 19, 2011, 07:35:52 PM
After removing the drivers for the parallel port, and the pendant brains from CNC4pc, the motor tuning will open now.
I guess my machine will only work with the PMDX 145 board for a pendant
JAckal :(
Post by: Hood on October 20, 2011, 01:00:32 AM
Do you have to remove both?
Post by: Jackal on October 20, 2011, 01:55:14 PM
Hood,
It works ok with the P-port driver installed, when you add the brains for the pendant & CNC4PC C-22 card, the "Config Motors" goes away.
You have to remove the P-port driver & brains, then re-install  Mach & sometimes re-install Windows, to get the motor adjustment back.
I do have the 2nd parallel port working now. ;D
JAckal
Post by: Hood on October 20, 2011, 02:06:18 PM
Sounds like the Brains for the pendant are screwed up, maybe email Arturo and see if he has any advice.
Post by: Jackal on October 20, 2011, 04:17:22 PM
Steve @ PMDX told me that if I can get the 2nd port to work, we can configure it with his #145 board that just came out.
I have seen a lot of problems with the  CNC4pc c22 board.
One guy said that  he  had to find some  ( Pull-up resistors ???) on the board and bypass them to get it to work.
I have searched and there are a lot of people having trouble getting it running.
I'll see what Steve says about it now.
Stay tuned,
JAckal :)
Post by: Hood on October 20, 2011, 04:32:54 PM
Yes, have also seen a lot of issues with these boards I am afraid to say. Thats why I like PMDX stuff, never seem to hear of issues.
Post by: Jackal on October 20, 2011, 05:14:20 PM
Hood,
Everything is back up and running.  Mach is feeding through the 2nd parallel port.
The motor tuning won't open up at all.
This morning,  I set Y and Z to the exact acceleration & velocity of my X axis.
Now they will still jog, but at a real low speed ( because I can't open the tuning to  speed them up.)  ???
I keep using this same .xml, since it has the settings for the 2nd Port, and took forever to  set-up. ;)
Could there be a setting clicked in my .xml doing this?
I'm not familiar enough with Mach to know.
JAckal
Post by: Hood on October 20, 2011, 06:23:13 PM
Cant think of anything that would stop the motor tuning appearing but if you attach your xml I will see if I can find something wrong.
Post by: alenz on October 21, 2011, 02:12:17 AM
Hood, I had that same thing happen a year or two ago, i.e. everything was normal except the inability to open the config> motor tuning.  That was on my office PC which has megs of crap loaded and therefore I didn’t suspect/blame Mach. I wasn’t able to fix it till I downloaded the next version of Mach.
FWIW just another data point.
Al
Post by: Jackal on October 21, 2011, 04:11:01 PM
Alenz,
Thanks for the info. I have been using a Mach version from about a year ago.( Don't know which  version).
This one giving me trouble  was downloaded about a week ago.
If I can find my old version, that's the one I'll install if this needs another re-work.
Right now, it's  working good and I figured out what it seems to be.
Using the the factory MACH .XML, and changing   the settings to those in  the PMDX.xml, works great.
For some reason if I try to load an .XML with any other name than the "Machmill.XML", it removes the option of  tuning the motors.
I have re-installed Mach  a dozen  times , and Windows XP about 9 or 10.
You can't put anything in the .XML name or it will screw up. Such as: 2mach3.xml, mymach3.xml, hurcomach3.xml, etc.
When it does mess up, you can go back and install the factory xml, and the motor tuning still won't open.
At least now, when things go crazy, you only have to  re-install  Mach, but  you  can't uninstall  Mach through Windows????
You have to search for all Mach folders and delete, then do a fresh install and re-boot Windows.
I am going to try again with the brains to see if it messes up. At least  it can be set back to where it is now, if something happens.
Also, you can change the address and  cable between the (2) parallel ports, and Mach will function fine  for either port.
Since  it recognizes both ports, it should allow a pendant. < ( For most people it would. Maybe not for me) >:D ::)
Hope this helps some else with similar problems. This is strange and may only apply to my computer, machine, and components.
If it will  stay the same, I can make notes of the glitches and remember what to do.
Usually, I run into problems that no one has ever had before,  and it's  for me only.
Jackal ;D
Post by: Jackal on October 22, 2011, 08:28:40 AM
Now everything works, except the pendant..
Mach functions great, the "Motor Config" opens every time.
Brains, .xml with different names can be installed/removed. No problems.
The enable button on the pendant works, and toggles the jog button on screen.
Something must be wrong with:
The pendant, or (wiring pin-out is wrong inside the one I have)
C-22 board is bad
The brains for c-22 are bad.
Mach will run on either port with a simple address change, and swap the cable to the different port.
JAckal
Post by: Jackal on October 23, 2011, 07:08:35 PM
Got  it all working ( most of it)
The pendant will jog now. ;D
Thanks for all of the help and listening to my  "Lunatic Ramblings." ;D
JAckal :)
Post by: Jackal on October 26, 2011, 01:52:31 PM
Update!
It's working now.  I took out the C-22 board and disabled the brains.
Configured Mach through the port pins and got 5+volts from the USB port.
Hope this helps someone.
Thanks for all of the help and suggestions
JAckal ;D
