Mach Discussion => General Mach Discussion => Topic started by: swanner on September 29, 2011, 12:31:06 AM
I have my router setup to measure tools from a fixed switch. I'm trying to modify it to where it touches twice, compares the values, and let's me know if it's out more than .002 off, then I want a message box to pop up with the difference in it. I'm getting a syntax error, probably something simple...
Not great at VB but think most of the syntax errors are because you have = > where likely it should just be > with no =
Also you have miissed out " at the end of the following
MsgBox("Check switch - " & Zpos - ZposC & "measurement error)
Should be
MsgBox("Check switch - " & Zpos - ZposC & "measurement error")
Then there is the CodeSingle, dont know what that is but Mach is not happy so presume it should just be Code rather than CodeSingle
I think you will likely have to put
While IsMoving()
Wend
after each movement command also.
For "greater than or equal to" the correct syntax is
not
Also has CodeSingle been released yet?
You also missed a couple of closing " around a statement or two.
Thanks guys! Works great now. The 'CodeSingle'...that's just the way the software came setup. I'm running an Industry Control MCB-1 and it uses a modified version of Mach, under the version it says R4.000.000 Test...anyway, I've attached the finished file with corrections if anyone else is interested in it.
YEP that won't run on a standard Mach ver.
