Mach Discussion => General Mach Discussion => Topic started by: fragger6662000 on September 28, 2011, 04:54:32 PM
Title: Save fixture
Post by: fragger6662000 on September 28, 2011, 04:54:32 PM
Gent's and ladies
I have been using mach for many years but just using the base co-ordinantes without using G54 or G28 commands, I don't see the need to run them on this machine as i don't have multiple setup on the machine and no repeatable tooling for length.
anyway i have switch to a different cam which uses g28 and g54 and i have a lathe setup and mill setup on the same machine.
When i exit and save fixture and reload it now does not remember the position.
Or is it just showing the g53 and not the g54 wcs?
thanks matt
Title: Re: Save fixture
Post by: Hood on September 29, 2011, 03:32:41 AM
The DROs show G54 by default, G53 is only seen when you have MachineCoOrds button active.
Have a look at General Config page and see if you have persistent offsets and DROs chosen.
Post by: fragger6662000 on September 29, 2011, 02:38:20 PM
i will hava a look.
thanks
Post by: fragger6662000 on September 30, 2011, 01:57:37 PM
seam tohave had that selected. another hood rescue!
