Mach Discussion => General Mach Discussion => Topic started by: 762x51 on September 21, 2011, 10:29:49 AM
Title: Index Pulse Problem
Post by: 762x51 on September 21, 2011, 10:29:49 AM
I'm in the process of converting an EMCO Compact 5PC Lathe to work with MACH3 and have the X and Z axis working fine but cannot get MACH3 to read the Index Pulse.
I drug out the O'Scope to take a look at the pulses and I don't see anything wrong there.
Attached is a drawing of the pulses and it looks like to me that they fall within the parameters mentioned in the MACH3 Turn manual.
Any thoughts or suggestions?
Orin
Title: Re: Index Pulse Problem
Post by: Hood on September 21, 2011, 02:11:41 PM
Can you attach your xml please, could be a config issue.
Post by: RICH on September 21, 2011, 04:02:36 PM
You will find info on setting up the index and testing in "Threading on The lathe"  write up which can be found in Members Docs.
