Mach Discussion => General Mach Discussion => Topic started by: ErrorFinn on September 17, 2011, 01:01:18 PM
Title: Proxxon MF70 and Mach3 setup...
Post by: ErrorFinn on September 17, 2011, 01:01:18 PM
I bought some days ago, a used  Proxxon MF70 with Usovo cnc 2008 kit, now i want use it with Mach3 software. I got only a assembly instructions, and now i need correct "pins" and other configuration data. The "default pins" are not working, after many hours of trying, i get some movement, but...
Title: Re: Proxxon MF70 and Mach3 setup...
Post by: Graham Waterworth on September 20, 2011, 02:15:33 PM
If you load up the original control software it should give you all the pin in/outs in the machine configuration page, all you need to do is then assign them in Mach3's ports and pins.
Post by: henk55 on November 19, 2012, 04:59:10 PM
Wel after some hours of searching the problem, I figured out that I had to change Estop pin#10  to pin#11
Then I press on the Mach3 RESET button, then Estop changed to Idle, after that I'll get the stepper motors working.
