Mach Discussion => General Mach Discussion => Topic started by: Q_alsayed on September 11, 2011, 05:54:25 AM
Hi
I need some help. I bought new machine with 3 axis. Also im new in CNC. I face problem with the setting up my machine. After I start running the program(G code), in the middle the program is stop due to Estope. Is there any part I need to check. I was thinking that happened because I have the free copy. But already I bought the license.
I appreciate your support.
Was there a message in the error bar?
Q alsayed,
1.First copy the license file to the folder where Mach3 was installed.
2.Post nformation about the cnc system you purchased.
3.Then at least look at some of the manuals.
Hi
thank you for replay
to Rich
i did no. 1, 2, 3.
the machine is from china. ( working travel 850,480,65.) stepper motor type (57 two phase 3A super-low noise)
spindle motor 0.8 kw VFD spindle .
spindle speed 3000--9000 rpm
resetting accuracy 0.05
the massage error is external emergency ...
i increase the Debounce Interval to 1500 but still after some time it is stop.
if i give sample job it is ok but if it is need cutting and pass more then one time i face the problem.
Likely either noise or crap switches, both common on Chinese machines I am afraid
Increasing the Debounce Interval more may help but really you want to probably sort out the wiring and properly shield and ground limits and possibly fit better limits if their quality is not great. Could also be the VFD as they can be noisy especially, again, the Chinese ones.
Hi hood
i check the wire it is ok
however, i try some think which i can not find the reason. my existing machine are running by windows 7. i change the machine and try to rub same file with other computer running by windows xp . it run with out problems. and it is old computer.
so how i can check the right computer suitable for the machine and program.
thank you.
