Mach Discussion => Feature Requests => Topic started by: Scott on December 15, 2006, 08:45:36 AM
Title: Safe Z on Feedhold
Post by: Scott on December 15, 2006, 08:45:36 AM
I'd like to have the choice to have the Z axis raise to the safe Z setting upon a feedhold with a return to depth upon resuming with cycle start.  The cutter can overheat pretty quick when left down in the material upon a feedhold shortening the life of the tool.
Title: Re: Safe Z on Feedhold
Post by: fer_mayrl on December 15, 2006, 10:47:18 AM
That is a great suggestion. And while were at it, how about the option of turning off outputs, and turning them back on on cycle start.
Regards
Fernando
Post by: Graham Waterworth on December 16, 2006, 04:59:47 PM
Not a good idea when using a t-slot cutter!
Graham.
Post by: Chaoticone on December 16, 2006, 05:59:40 PM
You can set it up now to do a safe Z on stop. In the safe Z set up.
Post by: fer_mayrl on December 16, 2006, 07:02:20 PM
Can It be done optionally when feed hold is pressed?
that way you can turn it off when using a t-slot, dovetail or keyhole cutter.
Regardss
Fernando
Post by: Chaoticone on December 16, 2006, 07:08:18 PM
I think you could just turn it off, uncheck it. There may be somewhere else like on the settings page, not sure. I'm running a different screen set.
Post by: Brian Barker on December 17, 2006, 09:46:17 PM
Not going to happen on a feedhold :( Stop only...
Post by: Scott on December 22, 2006, 10:54:36 PM
The problem with doing it on a "Stop" is that it's generally non-recoverable (meaning that I have to re-reference and start over).  As it is, if needed, I will hit "Feedhold" and then "Stop" to get the tool up and out of the material as quickly as possible.  Takes a little getting used to from what I normally would have done, isn't as quick to get the tool out, but at least you don't overheat the cutter or loose position.  Not that I do it everyday, but once in a while, stuff happens.  ;)
Post by: Hood on December 23, 2006, 04:17:20 AM
Scott
 not sure if it would work but maybe make a new VB button with the OEM for hold then stop. Would this work?
Post by: Hood on December 23, 2006, 04:30:53 AM
Just tried it and it seems to work but its just on the home computer and not on the mill so I cant be sure.
EDIT
 Nope wont work as when you resume the code it will just stay at the safe Z height until the next commanded Z move :(
Post by: Brian Barker on December 23, 2006, 08:51:13 AM
You could write the original position to a Var in mach3 and swhen you press resume you could have it move back to that position :)
Problem solved ;)
Post by: sshneider on December 23, 2006, 07:59:39 PM
Once again, I feel like I'm living in a cave and missing something...
If you feedhold first, then press stop, isn't this accomplishing the same thing.  I've done this a ton of times and have never noticed any missed steps or loss of position.  ????
Sid
Post by: Hood on December 23, 2006, 08:09:28 PM
Pressing hold then stop is the correct order to do things and you wont loose steps or position. I think what Scott is wanting to accomplish is to move the tool out of the work fairly rapidly on a feed hold. Depending on how his machine is set up that could be quite a slow process with having to press two on screen buttons. With a touch screen or physical buttons its not long but if using a mouse its a bit longer and iif there are high spindle speeds involved on a machine such as a router a second or two can burn the tool and workpiece.
Post by: sshneider on December 23, 2006, 08:14:34 PM
Aha, now I get it- Thanks...
