Mach Discussion => General Mach Discussion => Topic started by: john757 on August 29, 2011, 09:07:18 PM
I recently installed a PWM board to control my spindle speed. I keep getting the following error: PWM bumped to minimum setting. I can't find this error in any of the docs. What is the problem? Thanks for your help.
Hi John,
This error means that you have set the minimum PWM value to something other than 0%. So Mach3 is telling you that you are asking it to set the PWM to a value that is less that the minimum value to it is bumping it up to the minimum PWM value.
My guess is that if you look at the Ports and pins config tab for the spindle (attached image) you will see that the minimum PWM % is no zero.
Cheers,
Peter.
Thanks Peter. I will take a look at this setting.
John
