Mach Discussion => General Mach Discussion => Topic started by: Intarsicaq4 on August 17, 2011, 09:48:24 AM
Hi there!
Is it possible to install MACH3 in a laptop using a USB cable?
I have installed MACH3 in a PC using a parallel port, and works fine. Now, I am trying to use a laptop to drive my machine with MACH3, is this possible?
If so, where do I look for instructions to do this?
Thank You very much in advance for your help,
Intarsica
Only if you use one of the external motion controllers that work with Mach, SmoothStepper and KFlop are the two most common.
Hi
I've just got a smoothstepper and intend to use it on a laptop via usb.
Should I install mach3 with the mach 3 drivers?
thanks
Yes, you can use a laptop to control Mach3 with a SS.
You don't need to install the Parallel port driver.
The manual is here:
http://warp9td.com/documentation/SmoothStepperUserManualV1.0.pdf
Juan
