Mach Discussion => General Mach Discussion => Topic started by: slow on January 28, 2006, 08:32:30 PM
Title: softlimits
Post by: slow on January 28, 2006, 08:32:30 PM
I am having a problem using softlimits.
My configuration units are metric.  The X limit is 600 mm.  Softlimits seems to work fine.
If I change units to inches on the setup page softlimits stops the X axis at .93
instead of 23.6 inches.  Softlimits has shrunken my X axis by a factor of 25.4
--slow
Title: Re: softlimits
Post by: Brian Barker on January 28, 2006, 09:50:04 PM
Could you check you native units? This is under config system units. It sounds like it is set to inch...
Post by: Art on January 28, 2006, 10:04:06 PM
Hi:
  This is a known bug. It is recommended that you create a metric and an english profile. USe th eappropriate profile for metric or standard use untill the bug is repaired..
Thnks
Art
