Mach Discussion => General Mach Discussion => Topic started by: artnev on August 16, 2011, 10:54:02 AM
Title: Motor Tuning Problem
Post by: artnev on August 16, 2011, 10:54:02 AM
I need to tune my z axis motor but when I click on Motor Tuning nothing happens. Everything else in config works. Does anybody know what the problem is ?
Title: Re: Motor Tuning Problem
Post by: Hood on August 16, 2011, 01:17:25 PM
Is the driver installed properly? If you run the DriverTest.exe what does it say (its in the Mach3 folder)
Post by: artnev on August 17, 2011, 12:03:28 PM
The driver test wont work either. Everything else works as it should.
Post by: Hood on August 17, 2011, 12:24:49 PM
Can you attach your xml and I will see if there is a config issue.
Post by: artnev on August 17, 2011, 01:26:03 PM
Hood, thank you very much forr your help. I just tried the driver test again and inexplicitly  it worked. I then tried Motor Tuning and it worked. Problem Solved, (how?)
Post by: Hood on August 17, 2011, 01:31:52 PM
Ok what happened was you did not have the driver installed for some reason, running the driver test will install the driver so next time you started Mach or ran the driver test it would be fine.
