Mach Discussion => General Mach Discussion => Topic started by: sml2010 on August 15, 2011, 04:53:10 AM
Title: machine power question
Post by: sml2010 on August 15, 2011, 04:53:10 AM
Hi to all
I have a mini 3 axis milling machine.
My machine:
Step motor with 16kgf.cm torque.
I want machining a material with 150 MPA straight.
I want ask you that can my milling machining this material? I want know if my machine is able then i order material.
Thank you
Title: Re: machine power question
Post by: RICH on August 15, 2011, 05:17:21 AM
Most motors are rated by holding torque lb-in / in -lb or Nm. So  16kgf.cm dosen't relate well in my mind offhand.
150 MPA ?
How much HP is required to machine a material can be calculated ( value calculated is not exact ) and depends on spindle speed, feedrate ,depth of cut and machinability of the material. The mechanical aspects of the axis also plays into the above.
Then you also have the characteristics of the material due to  machining ie; some may work harden.
Nothing beats some experience so just try cutting some  similar material and see what it can do.
